EPDM Questions
camling | Posted in Construction Techniques on November 15, 2011 06:10am
I am planning to install Some EPDM on a small attached garage roof for a family member.  I have never done it before but i have been on site when a sub was doing it.  The current roof is roll Roofing over 1 inch board sheeting.  My plan is to strip the roof down to the original sheathing and cover that with 1/2″ OSB. This brings up the first question. How should i attach the OSB?  Are nails alright or should I use screws with those big washers?  Then I plan to attach the Epdm directly to the OSB. Is this acceptable, or is High Density fiberboard required?  I would appreciate any advice you can give about Epdm Installation!
Thanks Very Much ,
C. Lingler
  1. MikeSmith | Nov 15, 2011 09:43pm | #1
    if
    the original sheathing is  good....i'd  fasten the  hardboard ( high density fiberboard ) with  the screws and plates
    skip the osb
  2. seeyou | Nov 16, 2011 06:52am | #2
    +1 on skipping the osb
    unless you need it to stiffen the roof. You can adhere the epdm directly to osb, but you'll likely get better life out of it by using the fiber board. If you do elect to glue the epdm directly to the osb, screw the osb down, but don't use plates. The plates are for use on the fiber board.
  3. Piffin | Nov 16, 2011 05:26pm | #3
    You don't want OSB for this. If you need a wood substrate instead of recovery board use 3/8" ext ply and screw it off.
    OSB is not good ther if it gets damp after application and before EPDM, and it is too rough surfaced, so you would end up likely using a second coat of adhesive.
    The big plates are for the recovery bd or insulation board
