Does anyone remember which FH had the article about the epoxy finish for garage floors? Also does anyone know if the epoxy used can fill a full thickness crack in the slab foundation? In the garage, off one corner of the foundation, there is a crack about 12 feet long, 5 feet off one side and continues at almost a 45 degreee angle to approx 5 feet to the other side of the same corner. Not sure if that makes sense…….
Try to picture a rectangle with a corner almost cut off…..
Any help will be appreciated , Thanks, Dave
You can fill a crack with epoxy, though not the kind that is painted. Simpson makes a "crackpac" structural crack filler just for this purpose. However; you need to determine what caused the cracks in the first place and remediate that or more cracks may follow - especially deep, all the way through cracks - which are usually more than just settling/curing issues.
Griot's Garage makes a good product ... only comes in two colors though.
