Epoxy Paint delaminating from concrete
DavidThomas | Posted in General Discussion on October 1, 2005 12:32pm
Trying to help someone local who had a empty building get cold (was -30F outside) and burst pipes.  They pulled the carpet and some months after cleaning up they epoxy painted the floor.  It now has bubbles (or air?) where the epoxy has delaminated.
Why would this have happened?   I’m guessing bad prep, but could residual moisture in the concrete have been the problem?
Any fixes?
Thanks, David
  1. cawfy | Oct 01, 2005 01:00am | #1
    bump
    constantin | Oct 01, 2005 01:07am | #2
    I'd contact the epoxy paint manufacturer. Chances are, they've heard of this before.
    For example, was the slab prepped with muriatic acid? Was it completely dry? Etc. My guess is that you're on the money re: water percolating up.
  3. WayneL5 | Oct 01, 2005 02:08am | #3
    Epoxies are quite intolerant of moisture when curing, so that is a likely cause unless the slab was bone dry.  Could also be sealers, grease, carpet adhesive, or using the floor before the paint fully cured.
    1. DavidThomas | Oct 01, 2005 02:27am | #4
      Thanks guys.David Thomas   Overlooking Cook Inlet in Kenai, Alaska
