Epoxy removal
cjeden | Posted in General Discussion on April 2, 2003 07:41am
Hello all
I removed the outdoor “carpeting” that was covering the concrete stoops to my home–this is the stuff from the mid eighties – i’m guessing.
Well what I have now is a concrete stoop covered with hard as hell glue/epoxy–what ever it is it won’t come up easily. I’ve tried Muriatic acid–nothing, wire bristle head attatched to the drill–zippo.
Chiesiling it away is somewhat effective way–but ssssssssslow. I tired burning it away with “controlled burns” with mineral spirits and that actually is working prtty well.
I will be painting these stoops when they get cleaned up-and removal of glue is purely for cosmetic reasons.
Any ideas out there on how to deal with this situation?
cje
Take what you want, leave the rest
  1. FastEddie1 | Apr 02, 2003 08:30pm | #1
    Masonary wheel on a side grinder.
    Do it right, or do it twice.
    1. cjeden | Apr 02, 2003 08:38pm | #2
      that would probably work--but then I'd have to go out and buy one--which I'm not sure I can justify.
      good idea thoughTake what you want, leave the rest
      1. FastEddie1 | Apr 03, 2003 05:02am | #5
        Then you might try a belt sander with really coarse grit.  What about a metal rasp or coarse file?Do it right, or do it twice.
        1. CAGIV | Apr 03, 2003 05:18am | #6
          Or renting a grinder for the day, couldn't be to much money?View ImageGo Jayhawks
    BillHartmann | Apr 02, 2003 08:43pm | #3
    Well muractic acid is not an adhesive solvent.
    Look at the home horror stories for adhesive remover.
    If is is epoxy then heat will usually soften it.
    1. cjeden | Apr 02, 2003 09:02pm | #4
      yeah--I hadn't really thought about using an actual heat gun --that might work better then just lighting the step on fire--sort of the difference between a dumb bomb and a smart one--duh on me
      cjeTake what you want, leave the rest
Outdoor Lighting
