epoxy tile grout ??
Waters | Posted in General Discussion on December 12, 2008 07:03am
I’ve not used epoxy tile grout b4 and wondered:
Can it be had unsanded?
Can it be had in small qty’s?
Can u use/mix small qty’s at a time?
I want to use it to fill pits/voids in concrete counter tops after they come out of the mold–during the grinding/polishing phase.
I use std cementious unsanded grout for this now, and wonder if epoxy would eliminate the waiting before grinding and polishing again.
thx
Pat
    xxPaulCPxx | Dec 12, 2008 08:45pm | #1
    Q1:  Sorta.  I do know the Laticrete Spectralock comes in 3 parts, the A and B which are the two parts epoxy, and the colored sand as part C.  Mixing A&B will give you a hard epoxy, but you will need to somehow supply a color.
    Q2&3:  Go to Lowes and look in the tile section.  There you will find 2 quart buckets that contain the chemical mix either from Mapai or Laticrete.  That's small to sart with, but you can also make up a batch and freeze it before it cures.  On John Bridge, people talk about it lasting for months that way, and working perfectly when it thaws.
    Unasked Q4, Can I grind Epoxy Grout on Cement:  I don't know, but you can buy a small quantity to try, obviously.  I DO know that using a heat gun is about the only way to get this stuff out of the grout lines if you need to make a change.
    Tu stultus es
    Also a CRX fanatic!
    Look, just send me to my drawer.  This whole talking-to-you thing is like double punishment.
Mortar for Old Masonry
