Equipment for Sprayed-In Cellulose
| Posted in Energy, Heating & Insulation on September 25, 2002 05:57am
I work for a builder, i.e., I’m given all of the things that fall through the cracks, and have been given the task of learning about sprayed-in cellulose insulation.  Currently, we have fiberglass batts installed in the walls and loose cellulose blown into the attic.
I’ve read a good bit about sprayed celulose, including how to spray a uniform layer that will adhere to the wall cavities.  I can’t find much information about companies that make the equipment used to spray cellulose.  Does anyone have a opinion about which manufacturors are better?  Also, can one rent this type of equipment?
Any and all advice would be greatly appreciated!
ChrisA
  1. wflather | Sep 25, 2002 08:52pm | #1
    Chris,
    You are talking about wet-sprayed cellulose insulation?  I have had it done and contracted with a local supply company here in Central PA to do it, they have their own crew but also sub out some jobs to another crew from W PA, sort of itinerant insulators.  They had a huge blower installed in a panel truck, strong enough to dense pack using a 3" hose(!).
    The dry cellulose was mixed with a water spray as it left the blower hose, the water hose was duct-taped to the 3" cellulose hose and both were controlled by separate switches.
    Material that came out past the surface of the studs was shaved off using a 3' wide rotary brush that they simply ran along the surface of the studs, it was sort of shaped like a bow saw.
    Excess insulation was vacuumed back up off the floor using a hose connected to the suction end of the blower and re-used.
    They used 3 crew, one for each above jobs, trading off to make sure the hopper was full.
    The wet-spray process was very slick, you could try calling them and seeing if they are willing to share information:
    Lezzer Lumber
    Muncy, PA 17756
    (570) 546-8650
    1. Dant45 | Sep 25, 2002 09:52pm | #2
      Try http://www.krendlmachine.com.  They have insulation machines for about every form of sprayed or blown insulation.  DanT
      1. CHARITY116 | Sep 26, 2002 03:12am | #3
        Thanks guys.  I'll keep checking around.
        ChrisA
        1. joeh | Sep 26, 2002 05:37am | #4
          http://www.jrproductsinc.com/catalog.html
Mortar for Old Masonry
