Error with grouting
eagle4x | Posted in General Discussion on January 29, 2013 10:26am
I installed honey onyx tiles around the deck of my whirlpool tub with gap about 1/4″  and used unsanded grout on them. However, I found out afterwards that I should have used sanded grout because the gap is greater than 1/8″. Should I remove all the unsanded grout and use sanded before the tub is installed? If I don’t re-grout with sanded it would be very difficult to remove the tub later if the unsanded grout cracks. Thanks.
  1. DanH | Jan 30, 2013 07:05am | #1
    I assume this is fairly large tile, and not too large of an area, so removing all the grout is not a Herculean task.  Except that if you used a "fortified" grout (which one should use in a wet area) the grout gets a lot harder to remove.
    The best thing to remove the grout is an "oscillating multi-tool" with an abrasive blade.  Beats the heck out of a manual "grout saw" for this job.  You can purchase a multi-tool for anywhere from about $20 (at Harbor Freight) to $300 (for the top-of-the-line Fein tool).
    Hard to say if the unsanded will perform more poorly in this situation.  I think sanded is used in part for its appearance -- it just looks better in wider gaps -- but I believe it's also a hair more flexible, usually, and less apt to crack (or at least less apt to show cracks).
    1. eagle4x | Feb 02, 2013 02:10pm | #2
      Tile did not adhere well to backerboard
      Thanks for your reply. I decided to buy a rotozip and it worked very well removing the grout between the wall tiles. However, while I was using the tool under the schluter strip I cut 3 tiles (they are 12 x 12) and decided to remove them. However, while removing them they came off too easily except they adhered well where I had a put a piece of mesh tape along the top. If I don't remove the remaining tiles will they eventually come loose? Should I go ahead and replace them too? When I installed them I mixed the thinset to the consistency of peanut butter and let set for 10 minutes then applied with a trial - what did I do wrong?
      1. DanH | Feb 02, 2013 02:59pm | #3
        Not clear (so to speak) -- did the tile separate from the mud or did the mud separate from the deck?
  2. semar | Feb 08, 2013 10:02pm | #4
    grout failure
    You might want to post this question in the Tile Forum (john bridges)
    They are the experts - not to say there are no experts in this forum but they probably run into this more often .
    Did you use modified or unmodified mortar with your Schluter Kerdi?
