There was a resource online I had used a couple of times when there was something I hadn’t estimated before and was curious if anybody else used it or knew where to find it?
Obstacles are the things you see when you take your eyes from the goal!
The most common way to make your own parging mix is to use either Type S mortar for block or Type N for brick and add a concrete bonding additive.
Books and sites like that are only a hint or a guide unless you have an idea what your capabilities are to actually do the work.
But Craftsman Books has the National program for a free thirty day download trial,
or Hometechonline has a site with lots of help. I used to use themon a subscription basis.
Means Cost Data
There are several- as mentioned, Hometech and Craftsman both have them, and I believe Means still has one online.
As Piffin said, though, don't bank on the numbers being correct- they're based on national averages, and don't necessarily reflect your true costs of doing the work. What I've always done with any published data is compare a similar item I know my cost for to the value published for that item in the book or online source. If my cost was say, 20% higher, I'd adjust any published costs by at least that 20%- probably more just to play it safe.
Bob
Ha ha ha ha ha ha ha ! I found it i thought it was an excellent guide line for estimating just to cross check your figures.
