Estimating Software
| Posted in Business on April 15, 2003 07:10am
I am looking for a good bidding/estimating software. I do mostly residential custom new construction. I currently spend hours estimating time spent on various tasks and then adding them all up with material quotes and subcontractors bids and then cross check with my knowledge of what the cost per square should be. I want to have a data base that I can access and make adjustments to as needed. Any suggestions. Thanks, Dave.
Edited 4/15/2003 12:55:20 AM ET by dad
Edited 4/16/2003 10:55:01 PM ET by dad
  1. FastEddie1 | Apr 17, 2003 05:09am | #1
    Yep, you have two similar messages.  The other one is called Bidding Software.  You can delete the other one if you like.
    If you have some estimating history (sounds like you do), why not create an Excel spreadsheet with all you know?  There are several estimating programs, do a little search here and you'll find several discussions.
    Do it right, or do it twice.
Fast, Accurate Wall Framing
