Estimating software? pros, cons
j99t99 | Posted in General Discussion on May 7, 2008 10:42am
I am considering an addition on my home and was planning on performing an estimate to see if it’s financially viable.  (I am going to do as much if not all of the work myself.)  Does anyone recommend using a particular software?  or should I just  do a take off estimate from my chief architect software package.  Any ideas for a handy home owner.
thanks in advance for any advice.  p.s.  I am in Fanwood, New Jersey, Union County.
Tim
Tim
  1. rez | May 08, 2008 04:44pm | #1
    Greetings Tim,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    Click here for access to the Woodshed Tavern
    Click here to visit the beginning of Breaktime
  2. CAGIV | May 08, 2008 06:52pm | #2
    If you're doing the labor yourself and you have a take off from Cheif, I'd use the take of to get a rough idea.
    It probably won't be dead on but should be close.
    An estimating program isn't going to help much because you'll have to set it up with your local and current prices plus change all the assumptions for fit and finish items.
    Figure out what you want to put in the addition in terms of fixtures, flooring, trim, windows, doors, etc and get local prices, a program isn't going to do that any easier for you then a spread sheet.
    Get prices from the sub's you'll use, add in the material from the take off, and go from there.
    Team Logo
  3. DanH | May 08, 2008 10:00pm | #3
    A point to ponder: I can virtually guarantee you that the estimate for writing ANY of the popular estimating software packages was off by a factor of two. You gonna trust your estimates to that?
    What is wanted is not the will to believe, but the will to find out, which is the exact opposite. --Bertrand Russell
