I have a fair amount of doors that need to be drilled for Eurohinges, and I want to buy a jig. Does anyone have any experience with any of the jigs available from Lee Valley, or woodworkers supply? Or any others? I really don’t want to make my own jig or use a drill press, as some are still in the shop, and some are on the job already.
How the work of a home-performance professional can result in a path toward improved energy efficiency, durability, and health.
I used a jig from Rockler many years back. It was pretty good, though it took a bit of adjustment to get right (always make up a dummy first!). I believe they've improved signifcantly since then, and Rockler, last I looked, had a better selection of jigs than Lee Valley.
Blum boring jig
Back when I used to work in a cabinetmaking shop, we had a Blum brand boring jig that chucked into the drill press and bored the cup hole while simultaneously predrilling the mounting screw holes. The jig consisted of an auxiliary table, fence with swinging stops on both sides, a multibit gear head set exactly for Blum hinges, and vertical spring rails that the head rode on. It even had a swinging hinge inserter but we never used that.
Unfortunately Blum must have not been very interested in producing quality jigs and doesn't offer the same jig anymore. But if you look at the design of a Blum Mini-Press, it is essentially the same thing with a motor. BTW, a used Mini-Press can usually be found on Craigslist or Ebay for around $700 if you had the time and money to shop around.
Fortunately, there are a couple companies that have started making a jig similar to the Blum. Most notably, CMT and their CMT333-03 Universal Hinge Boring System; about $320 online. While it is not quite as nice as the Blum jig I used, it appears very close and by adding a larger plywood base, longer fence, and a couple of swinging stops would be an easy upgrade.
http://www.cmtutensili.com/show_items.asp?pars=PJJ~CMT333~2
DC
I have the Lee Valley jig and their system 32 hole drilling jigs. Both work fine. Not sure I would do production work with them but for short runs, they are fine.
