Im wondering about a floating slab that is keyed into a stemwall by means of having a 4 inch recess on the top of the 8 inch stemwall, so then the slab gets screeded off at that height.But now we frame partway onto the slab. It seems to me the slab should of butted into the stem.I know we frame bearing interior walls on the slab with footers under so maybe its not a problem. Im wondering if Im just neurotic or there is room for concern? Thanks in advance.
Dehumidification is listed as a selling point for HPWHs, but are they actually effective at lowering humidity?
A Modern California Home Wrapped in Rockwool Insulation for Energy Efficiency and Fire ResistanceRelated Stories
Podcast Episode 665: Rough Concrete, Good Workwear, and Framing a High-Performance House
Podcast Episode 664: The Best of the Fine Homebuilding Podcast, Volume 8
FHB Podcast Segment: The Best of the Fine Homebuilding Podcast, Volume 8
Podcast Episode 663: Green Stains, Larsen Trusses, and Insulating Behind Stucco
What does this question have to do with expansive soil?
*You are neurotic. Hope that makes you feel better.
*Well john expansive soil and floating slabs go together because of earth movement.If the slab heaves under bearing walls you get drywall cracking or worse.So my question was if they should have butted the concrete into an expansion joint instead of what was done.So we would be framing on the stemwall only.Now it has been verified im just neurotic so I feel better already. Thank you
*"I know we frame bearing interior walls on the slab with footers under so maybe its not a problem"So you're thinking that portion of the floating slab won't float?Good luck; I inspected a house like that a couple of years ago and the walls, ceiling and roof were a disaster!
*that is how I did mine, and alot others around here, but we do not have expasive soil in this area. we got sand, white, red, tan sand, everywhere sand. what we call clay is really sand.
