experiment- hardi board
brownbagg | Posted in General Discussion on October 2, 2005 05:33am
we was talking about the water protection of hardi board last week, so I started a test. i silcone a jug to a piece of board and filled with water.
  1. brownbagg | Oct 02, 2005 05:35am | #1
    I forgot pictures.
    1. brownbagg | Oct 02, 2005 05:41am | #2
      six and 1/2 hours without moving, see the blue line.
        Matt | Oct 02, 2005 05:55am | #3
        I guess you are using hardi-backer...
        BTW - that is never gonna work right.  You used the wrong color of caulk... ;-)
        maddog3 | Oct 02, 2005 06:02am | #4
        .....yeah.......................I see it ,is that it .......under the clock ?"
      Gunner | Oct 02, 2005 06:05am | #5
      What kind of truck is that?
      1. brownbagg | Oct 02, 2005 06:12am | #6
        the blue line is above the clockthat is the body to this truck. I had to do some welding on the frame.
          Gunner | Oct 02, 2005 06:18am | #7
          Cool. Alabamas answer to  Jesse James.
          So what's the pupose of the experiment? To show that the water won't soak through?
          1. brownbagg | Oct 02, 2005 06:29am | #8
            just something I need to know.My great grandfather had a mule killed by the real jesse james in ne arkansas. that was a mean man
            Gunner | Oct 02, 2005 06:39am | #9
            Mule was probably snoring or something hideous. There's a place not to far away from here that used to be a hotel now it's a house. He'd hide out there. Legend has it that there was a tunnel to another house.There he fathered a child by a local girl. Or something like that, I just wanted to fix the electric and get out when the old lady was babbling on about it.
      JeffBuck | Oct 02, 2005 09:23am | #10
      is the top (uuh ... bottom) open?
      waters gonna evaporate and ruin your test results.
      Jeff    Buck Construction
       Artistry In Carpentry
           Pittsburgh Pa
      1. brownbagg | Oct 02, 2005 03:43pm | #11
        yes you right, just mainly seening if it will seep througth to the bottom side
          maddog3 | Oct 02, 2005 05:06pm | #13
          ...so what happens if it does leak??
          1. brownbagg | Oct 02, 2005 05:44pm | #14
            18.5 hours.somebody said hardi board wasnt waterproof. I have been using my shower without tile yet. I just like to know.
            maddog3 | Oct 02, 2005 06:06pm | #15
            I had to do the same thing in my bathroom, but I hung some plastic over the Hardi ,....... because I already had enough headaches in there..
            what about the joints? won't water seep into the cracks?"
          3. davidmeiland | Oct 02, 2005 06:16pm | #16
            Try cutting some pieces of equal size, weighing them, then soaking half of them in water and weighing them later. Apparently Hardi siding will absorb 1/3 of its weight in water, which means it is holding quite a bit of water against your building.
            Besides, it's not necessarily straight thru the board that the leaks occur, it's at the joints. Once you have water leaking in around a window, Hardi board will absorb quite a bit of it and keep it there.
          4. brownbagg | Oct 02, 2005 08:05pm | #17
            its been over twenty hours and it starting to seep through. This is with a head of water sitting on top. I think it could handle a shower with no problem.
            Gunner | Oct 02, 2005 08:47pm | #18
            This is getting like that gun cam Jeff Buck posted a link too awhile back.
          6. Kowboy | Oct 03, 2005 10:17pm | #19
            May I suggest another experiment?
            Cut an orange/lime/grapefriut in half and set it on a piece of granite countertop.
            Result?  It soaks through!
            Set it on a piece of solid surface or engineered stone, nothing.
            I haven't tried this with chicken yet.
          7. custombuilt | Oct 04, 2005 12:50am | #20
            Good stuff---  I bet wonderboard would last about 10 seconds
             When in doubt, get a bigger hammer!
          8. ss3964spd | Oct 04, 2005 07:26pm | #21
            How are you going to get the chicken to hold still?
            Dan
  2. dustinf | Oct 02, 2005 04:05pm | #12
    A friend did a test of hardi backer when it was first available.  He cut about 15 pieces 3"x3", and dumped them all into a bucket of water.  The first week he cut 3 pieces in half to see if they had soaked through.  He repeated the process for a month, and none of the pieces had soaked through.  He left a couple pieces in the bucket for a few months, but the water started to stink, so he ended the experiement.
