exposed screw tips!!!
SimonThompson | Posted in General Discussion on January 24, 2014 01:09am
standing seam roofers just finished what i think is the best looking roof i have seen yet,
but in the covered porch/entry area the 3″ screws came through 1/4″+- on the finished vgf ceiling.
also on some spots on overhangs.
my question is how the hell do you fix this?
bung cutter around tip then how do you cut a very thick ss screw in a small hole?
help!!!
simon
  1. Norman | Jan 24, 2014 01:22pm | #1
    Another job for the Dremel.
    Put a carbide cutting disk in a Dremel and it will eat thru the screws very quickly.
    But, unless the screws are stainless steel, the exposed bottom of the screw will rust unless it is sealed.
    IMHO, I would let the contractor fix it correctly, with shorter screws.
    Good luck.
  2. jimblodgett | Jan 24, 2014 03:08pm | #2
    Oh man.
    Sure glad that wasn't me.  That time.
    How many square feet of ceiling are we talking?
    How noticable are the screws through the overhangs?
  3. AndyEngel | Jan 24, 2014 03:28pm | #3
    Ouch
    Sounds to me like there's an expensive ceiling fix in the works no matter what. One option might be to leave the screws alone and install a second ceiling.
  4. calvin | Jan 24, 2014 06:28pm | #4
    damn
    An ALMOST perfect roofing job.
    Call 'em back.  Shorter screws and fix the holes.
  5. SimonThompson | Jan 25, 2014 10:14am | #5
    all good ideas,
    might try to band aid this as best as i can,
    maybe cut flush with dremel like someone said and then paint the end of the stainless screw
    with a matching nail polish?
    overhangs are soild stain so i can do the same and touch those up with primer and stain.
    so frustraiting to pay so much for a roof and have this kind of thing happen.
    there is no excuse but might have had somthing to do with neer 0 degree weather,
    oh well the roof itself is very very nice and should last as long as im around
  6. sapwood | Jan 25, 2014 11:58am | #6
    Unfortunately, if that ceiling paneling is also the roof sheathing, the contractor can argue that installation guidelines call for fasteners to penetrate by x amount.
Picture-Perfect Pergola
