Ext. Trim Around 16×7 Garage Door
PLUM72 | Posted in Construction Techniques on October 14, 2008 01:13am
I need to replace some rotting brick mold around my 16×7 garage door opening.  Rather than repalcing the brick mold.  I’d like to dress it up a little.  I was considering 1-by material around the door with a decorative cap.
What width do you guys use when trimming a garage door opening?  1×6 or 1×4 or something else?  Is it different top and sides?
When adding a decorative cap such as a bed molding or a small piece of crown at the top what material are you using?  The only thing I can find locally is pine.  To me it looks like interior stuff.  I suppose it might be okay properly primed, painted & flashed.  Material thoughts?
  1. rlrefalo | Oct 14, 2008 03:37am | #1
    You could use azek or koma pvc products. Use 5/4 thickness though. Bed mold and other profiles are available too.
    Rich
  2. NEXTLEVEL | Oct 14, 2008 01:45pm | #2
    Use the Azek trim.  It is made of PVC and comes in many different profiles.  I would suggest a 1x6 on the sides and a 1x4 with backband on top.  On top of the backband you can put a 1x6 with 5 12 crown.  Looks real dressy.
    James
    Jeff_Clarke | Oct 17, 2008 03:24pm | #3
    All wood around doors is Spanish cedar - copper cap on top
  4. JeffinPA | Oct 22, 2008 03:57am | #4
    Yep
    Azek
    I use 5/4x4 all the way around but that is inexpensive housing.
    Better is 5/4x6 on top and 5/4x4 on sides in my opinion
    AZEK has numerous profiles and you can do crown or bed with a cap if you want real fancy
