Exterior Casing for Thick Storm Door
user-88093 | Posted in General Discussion on January 21, 2006 04:16am
Good Day
I bought a wood screen/storm door kit for installation in a new rough opening in my house. The door is 1 3/8″ thick so the standard 1by trim will not do.  I could use stardard 2by Kiln dried pine though I’m not sure it will stand up to the elements, and it has a rough look even when painted, as this will be. Also its too thick.  Should I be looking at other kinds of lumber for this application, or perhaps mill down the 2by?
Handy Dan of Boston
    MarkH | Jan 21, 2006 05:24pm | #1
    Will 1" thick 5/4 work? you could put a spacer under the trim to shove it out a bit also.  Put a band around the edge if you need to dress it up.
    Edited 1/21/2006 9:27 am ET by MarkH
  2. ms | Jan 21, 2006 11:21pm | #2
    Build up the trim? Maybe 1X (3/4") under brickmold and that would give you 1 3/4 thickness on the door side.
    Mark
    NickNukeEm | Jan 22, 2006 03:19am | #3
    I've used clear cedar decking lumber, both 2x framing lumber and 5/4 decking for exterior trim where added beef is required.  Plane/saw down to desired thickness.  Added benefit is that cedar is more resistant to insects/rot than pine.
    "I am the master of my fate, I am the captain of my soul."  Invictus, by Henley.
Drafting the 2027 IRC
  • The New Old Colonial
