exterior cement plaster over wood frame
matasky | Posted in General Discussion on June 26, 2007 02:00am
hey fellas…i’m about to finish off a small garage, which has block walls to a height of 48″, with a cement plaster finish which is the norm here in sunny bermuda…i am to finish with stud framing…don’t ask why 🙂
my question lies with the exterior finish…i would like to finish it with a cement plaster as well, but wonder which sheathing/lath combination i should go with..wood rot is an extreme problem here…i’m leaning towards cement board (with joints filled)/lath (diamond metal or plastic??)/plaster, or else i could go with plywood/building paper/lath/plaster..
all opinions would be appreciated, especially from anyone in the southeast….
    copperjohn | Jun 26, 2007 04:27am | #1
    here in new england we have had good results using wonderboard and driv-it for the top coat, just make sure that you put the rough side out so the dri-vit adheres... good luck copperjohn
  2. Piffin | Jun 26, 2007 04:58am | #2
    Here in the states we call that stucco.
    sheathing, then tarpaper, then expanded metal wire lathe and two or three coat stucco job
  3. Piffin | Jun 26, 2007 05:00am | #3
    i am thinking the critical issue would be the join between the existing block with finish and the new above it. If the desired effet is to hve both finishes on the same plane, you will need a good Z-flashing to go under the tarpaper and over the existing
Drafting the 2027 IRC
  • The New Old Colonial
