I have to build an exterior door for my father-in-law. It will be roughly 3’X 7′. Aesthetics are not the primary concern, cost and insulating abilities are though. It is a back door for his butcher shop and will be 4 to 6 inches thick. I am concerned that if I use standard spruce lumber for the framework and plywood skins that it will warp and not seal well. Would 3/4″ plywood ripped and laminated together for the frame be better or simply unnecessary work? As is probably obvious I don’t really know where to start with the design but do have moderate carpentry skills so I don’t think the actual construction should be too bad. I searched the archives but could not find what I was after, any help or
direction would be greatly appreciated.
Thanks, Jason K.
Listeners write in about ambitious projects and sinking patios before asking questions about old house specialists, attic headroom, and home shops.
Older walk in cooler doorss were built the 4x4 method, stayed flat for years when oil base painted. Mortice/tenon 4X4s for frame, fill with insulation, cover with 3/4 plywood. You may have to recess the thickness at the locks (more 4x4 backing there)to get standard door hardware to fit.
*Thanks Art, much easier this way, save ripping the plywood. Jason K.
I have to build an exterior door for my father-in-law. It will be roughly 3'X 7'. Aesthetics are not the primary concern, cost and insulating abilities are though. It is a back door for his butcher shop and will be 4 to 6 inches thick. I am concerned that if I use standard spruce lumber for the framework and plywood skins that it will warp and not seal well. Would 3/4" plywood ripped and laminated together for the frame be better or simply unnecessary work? As is probably obvious I don't really know where to start with the design but do have moderate carpentry skills so I don't think the actual construction should be too bad. I searched the archives but could not find what I was after, any help or
Thanks, Jason K.
