I have a house bedford stone veneer exterior. I am working with a cottage style for the outside and I really need to visually trim the windows and doors. They do not have any trim. Because of the random thickness and shape of the stone this could be /is a real challenge. Currently there is only about 3/4″ that is showing from the vinyl window casing. I want to have 3 or 4″ wide trim around the openings.
Does anyone have any tricks, secrets, or suggestions for how to approach this?
Understand lumens, ceiling brightness, beam spread, tilt, and color options to make a wise choice on a common fixture that can range from $75 to $750 or more.
I have a house bedford stone veneer exterior. I am working with a cottage style for the outside and I really need to visually trim the windows and doors. They do not have any trim. Because of the random thickness and shape of the stone this could be /is a real challenge. Currently there is only about 3/4" that is showing from the vinyl window casing. I want to have 3 or 4" wide trim around the openings.
