Exterior electric box on deck
rickchem | Posted in General Discussion on June 22, 2007 06:48am
I’d like to add an outlet box to the underside of my deck.  Easiest way seems to run 12/2 UF sunlight resistant cable (~40′) directly from breaker inside the house, through the open framing in basement, and along the underside of the deck to an exterior box with a GFCI outlet.  By my read of the NEC, since all wire will be within framing, no need for conduit, and UF is usable in same applications at NM interior.  Sound proper?
 I know- get an electrician- but I’d like to know the “correct” way before I proceed.  I need to get an electrician for the permit regardless.  I guess I’ve seen too many shorted wires and shoddy work to just sub it out blind.
    IMERC | Jun 22, 2007 02:30pm | #1
    be safe...
    tube the wire in the exterior application...
    WOW!!! What a Ride!
  2. marv | Jun 22, 2007 04:01pm | #2
    I wouldn't bother with conduit.
    You get out of life what you put into it......minus taxes.
    Marv
  3. FHB Editor
    JFink | Jun 22, 2007 04:38pm | #3
    Definitly go with conduit. The wires will be exposed to damage within the open deck joists. I'm not sure if it's code required (seems like it should be!), but it's cheap and good peace of mind.
    keeps the squirrels out too...they like romex.
    Justin Fink - FHB Editorial
    Your Friendly Neighborhood Remodelerator
    1. edlee | Jun 22, 2007 04:56pm | #4
      Damage from what?
      Ed
      1. FHB Editor
        JFink | Jun 22, 2007 05:50pm | #6
        << Damage from what? >>
        Who knows? wildlife, freeze/thaw cycles, an errant broom handle? Why chance it?Justin Fink - FHB Editorial
    2. dukeofwsu | Jun 22, 2007 05:47pm | #5
      Romex in conduit??? Careful about clarity here.
  4. myhomereno | Jun 22, 2007 06:01pm | #7
    Why not use BX cable?
    MArtin
    1. bubbajames | Jun 23, 2007 01:01am | #11
      BX is not for exterior uses... I agree with the idea of uf in conduit.
  5. DanH | Jun 22, 2007 06:44pm | #8
    Basically sounds good. The cable should enter from the side or (better) bottom of the box, to minimize moisture entry chances.
    Sunlight-resistant UF should be fine (and almost overkill) if reasonably protected within the deck structure. Plastic conduit or watertight flex would add a small amount of additional protection (UF is pretty rugged by itself), but hard to say if it's worth the trouble without seeing how complex the install would be.
    Note that if you use the plain UF you may need additional mechanical protection near the box, depending on how it's exposed. Also, some consideration is needed re the entry of the cable into the house, both in terms of mechanical protection and water exclusion.
    1. rickchem | Jun 22, 2007 08:04pm | #9
      Some clarification- the deck is about 2-3 feet off the ground, so no traffic underneath but I suppose potentially some animals could get in there.   The wire would come through the ledger board and be tacked to the side of a joist all the way to end of deck- or at least that is what I envisioned.
      I thought about conduit, but I've heard conflicting things about the propriety of running UF in it for extended lengths (in this case, the exterior portion of the run is 16').  It would not be that difficult to run.  Can the conduit terminate indoors in the framing with a nipple and then continue with the UF to the breaker?  I didn't want a box at the interior/exterior line since the framing will be covered eventually.
      Thanks!
      1. DanH | Jun 22, 2007 08:26pm | #10
        UF is more rodent-resistant than regular romex. We were using it in Puerto Rico because of it's added rodent resistance. It may well be more rodent-resistant than standard plastic conduit.If you carry conduit into the house, you should be able to terminate it with just a bushing (to prevent the conduit end from cutting the cable), vs having a box where the cable exits.The rules about derating multiwire cable in conduit are a little obscure, so some code lawyer will have to quote you chapter and verse. Keep in mind, though, that UF is larger/stiffer than regular romex (if indeed you use UF in the conduit) and will probably require larger conduit.
          BillHartmann | Jun 23, 2007 03:01am | #12
          There is no code for derating cable in conduit. Cable is conduit is treated just like individual wires in conduit for the purpose of deraing.No more heat buildup being in conduit than being burried in the middle of an insulated wall.For pulling cable in conduit you need to treat it as a single wire the diameter of the larges dimension of the cable.Conduit can also be used to sleave wire to protect it from physical damage (needs to be sch 80 if PVC). While the code does not specficially say anything about practice is to all a smaller condit where the cable just fits. For examp to protect a NM drop from the joist to the receptacle on a basement wall..
          1. DanH | Jun 23, 2007 05:33am | #13
            Seems like every time the issue of cable in conduit is raised there's a different answer on derating.
            BillHartmann | Jun 23, 2007 05:50am | #14
            There are only two answers.One that the code is silent on this.And all of the wrong ones..
Drafting the 2027 IRC
  • The New Old Colonial
