Exterior Foam Trim Adhesive
NickNukeEm | Posted in Construction Techniques on July 4, 2005 03:49am
Any good suggestions foran exterior foam trim adhesive?  I don’t use the stuff much and I need to glue some returns to a cornice and would hate to melt away the foam.  (This stuff isn’t the cellular plastic trim like Azek, but appears to be more of a foam core.)
I never met a tool I didn’t like!
  1. Piffin | Jul 05, 2005 06:42am | #1
    There are different kinds of foam. Got a name brand? The Fypon is a urethene foam - crean/tan in colour and about as dense as white pine. Their adhesive is PL Premium, some of which is making my hands black right now, 'cause it sticks so well.
    I know there are other exterior foam trims made of styrafoam, which migtht melt down from the PL Premium. They make PL 300 for styrafoam. I believce that Geocell caulk would work also, but it is designed less as adhesive so clamp time would be long. The bond is a suction bond rather than chemical.
      NickNukeEm | Jul 06, 2005 02:11am | #2
      I believe it's called 'Never Rot'.  It's not dense by any stretch, hard plastic shell and lightweight foam core.  I figure I'll cut a few pieces and try out some Azek cement, PL premium, and LN for foam .
      Thanks.
      1. Piffin | Jul 06, 2005 05:54am | #3
        Google found me this
        http://www.royalgrouptech.com/Products/trim.html
        which led to this
        http://www.royalmouldings.com/
        which linked to an install page that lists several types of adhesive for various uses:
        http://www.royalmouldings.com/HowTo%20Files/How%20To%20Install,%20Paint,%20and%20Touch%20Up%20Royal%20Cellular%20Vinyl.pdf
