Exterior Plumbing Access Panel
mrjames | Posted in Construction Techniques on July 20, 2009 05:30am
I’ve got a customer with an exterior access panel which, over time, has allowed water to get into the wall and rot out the framing.
I need to build/install a watertight access for them in addition to fix the framing.
Has anyone built a watertight access? I was thinking about building a casing out of p/t wood with a latched door with weatherstripping on the inside.
What do you think, is there a better way or a product out there for this.?
  1. DonCanDo | Jul 20, 2009 08:11pm | #1
    Water is insidious.  Weather-stripping is a good idea as a second line of defense, but I would think about making a cover that prevented water from even getting that far.
    Consider how windows are done.  Can you mimic that?  For example, casing with a rabbet on 3 side (top, left and right) and a panel that slides up and behind it.  You could use v-strip weatherstripping to keep it snug and act as a secondary barrier. And of course you would need some kind of latch to keep it from sliding down.
    If there's a manufacturer of a ready-made exterior weather-tight access panel, that would be my first choice, but I don't know of any.
    1. Shacko | Jul 20, 2009 09:40pm | #2
      If you Google access panels, you will find many sites.
       "If all else fails, read the directions"
  2. Frankie | Jul 20, 2009 10:00pm | #3
    Think of the access space as an exterior niche... with a superfluous door on it. Basically you need to waterproof the framing as you would a shower niche except the water would have to shed onto the finish surface rather than the substrate.
    How about using a laundry box, custom bored to accommodate your needs? Then caulk all penetrations.
    Just some thoughts.
    Frankie
    Flay your Suffolk bought-this-morning sole with organic hand-cracked pepper and blasted salt.
    Thrill each side for four minutes at torchmark haut. Interrogate a lemon.
    Embarrass any tough roots from the samphire. Then bamboozle till it's al dente with that certain je ne sais quoi.
    Arabella Weir as Minty Marchmont - Posh Nosh
