I was wondering if anyone has had any luck with putty in exterior applications where the trim may not be painted for a good length of time. I’m filling the nail holes in exterior trim in New England and it will not be painted until spring. Any suggestions?
In older homes like these, the main remodeling goal is often a more welcoming, more social, and more functional kitchen.
Me too!
Painting decision kept getting put off, now we're toast!
Sherwin Williams goes on as low as 35 degrees, but I'm afraid we won't have too many of those anymore.
I anxiously await the answer to this one!
Jake Gulick
[email protected]
CarriageHouse Design
Black Rock, CT
I've used Elmer's exterior wood filler with good results, as long as the wood is primed after the stuff is dry. I prime with Kilz, latex most often, again with fairly good results. If the putty gets wet, however, use an oil based primer, as the putty will bleed through mulitple coats of latex. The SW low temperature paint is pretty unremarkable stuff; I've tried it, was unimpressed (doesn't hide squat) and will not use it again.
But that's just me. Your results could be just what you need.
A local painter, a good one by my estimation and general reputation, uses two-part auto body filler. Seems to work in cold weather. Of course 'cold' is a relative term as this is Florida. I have seen him use it with success in the 30s F. He mixes up a batch on a shingle and puts it on with a nylon spreader getting it very close to finish so there is minimal sanding.
He claims it absolutely guarantees that the nail heads won't pop, shadow or rust through. Only thing it is a weak choice on moving joints as it has no flexibility. Of course a good caulk would be better in this situation.
I "love" Minwax's two part epoxy filler. Dries fast (but not too fast) and is easy to sand. Theres been times I've made molding out of it..lol
BE sculptured
andy
My life is my practice!
