exterior siding with azek
drbgwood | Posted in General Discussion on July 16, 2005 07:26am
I just replaced the lower windows and the exterior woodwork on the bottom 3 feet of a 2 story baywindow unit.  It had rotted around the bottom due to water infiltration.  I addressed the causes of the problem by using propler flashing, jambsills in the window openings, dripedges, dripcaps and so on.
To replace the exterior wood work of the bay that had gone bad, I used azek.  I carried the azek from the surface of the deck to 3 feet up the wall and then will make a transition to the existing wood with a chair rail.
A question that came to mind while doing this, is that azek, being pvc, would be a solid vapor barrior.  Of corse for small peices of trim work, this is no problem.  But it’s my understanding that a vapor barrier on the exterior side of the wall is asking for problems with condensation inside the wall.  How big of an area could you cover with PVC composite before you start trapping moisture?
I’m not planning to side an entire house or anything like that, but I could see doing exterior waynscoting with the stuff.
  1. rez | Aug 14, 2005 10:26pm | #1
    Greetings dr-,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
    Perhaps it will catch someones attention that can help you with advice.
    Cheers
    A person with no sense of humor about themselves is fullashid
  2. rez | Aug 20, 2005 09:55pm | #2
    In the event you don't receive an answer here it might be worth a try at the JLC forum.
    http://www.jlconline.com/cgi-bin/jlconline.storefront
    Spaghetti? The secret is in the sauce!
    Hunts with garlic.
Grout-Free Shower Panels
