Exterior stucco question
montanajp | Posted in Construction Techniques on April 8, 2005 01:53am
I am remodeling a small (750 sf) 1930’s cottage and the plan calls for stucco on the exterior. I will remove the old siding/ felt and want to bump up the R-value of the 2×4 walls by applying 1″ foam board over the exterior sheething.. My question is, should I apply Tyvek over the sheething, followed by the foamboard, then felt, then metal lathe? Also, is the felt layer really necessary? The best stucco guy in my area recommends it because it will “buckle” from the moisture in the wet stucco, creating channels to allow condensed vapor to migrate downward towards metal flashing and to the outside.
Not sure if it matters, but about half the house has sprayed foam insulation in exterior walls, the other half has fiberglass bats. Also, any thoughts on Cement vs acrylic based stucco?
Thanks! Montana JP
  1. FastEddie1 | Apr 08, 2005 04:00am | #1
    Tyvek makes a product specifically for stucco.  It comes pre-wrinkled ... looks like crepe paper.
    1. montanajp | Apr 08, 2005 06:34am | #2
      Thanks Ed. I will look into that Tyvek product.
      1. stuccoman | Apr 14, 2005 12:16am | #3
        Be sure to look at raindrop by pactiv. A greenguard product!
FHB Podcast Segment: Sometimes Spray Foam Makes Sense, Sometimes It Doesn't
Spray foam is a great invention, but it's not always necessary.
  • Tall Deck on a Sloped Lot
