Would you use regular 2xs for exterior trim if they are painted? Cedar 1xs are a bit too narrow next to clapboards. And I have extra wood that I could use.
Thanks,
Steve
Thanks,
Steve
This compact detatched accessory dwelling has an efficient layout with a vaulted ceiling that enhances the sense of space.
Do you have access to 5/4 cedar stock? That should be enough to clear the claps.
I don't know if the local stores carry 5/4 or not. But I was thinking more of what I had left over from the framing.
or get out the planer.
Half of good living is staying out of bad situations.
"or get out the planer."
I guess that is why I was thinking 2xs, less effort.
>>>"Would you use regular 2xs for exterior trim if they are painted?"
No.
Why not? Thickness or quality of lumber?
I f that's the look you like why not? Your probably not going to use any wany edges, are you? You can also pad out the 1x you thought was too narrow.
no turn left unstoned
Actually, from a distance I can't tell whether something is 1x or 2x can you guys?
Personally, I prefer taking 2x cedar and rabbetting out 1" wide by (x) depth so that the face of my siding is buried behind the face of my trim and you don't end up with high maintenance caulking at a butt joint.Just a thought, hope it helps
If the two by stock is spruce, it will twist. It can twist enough to pull itself off the house at places.
I'm just now finishing up one where I furred out the 3/4" corner boards with scrap plywood (Ooops, you already threw those scraps away???) to add the dimension.
