Is the following wall design good or bad? I’m looking for a tight wall with no air infiltration. I’m not nut’s about poly.,ADA etc. they seen awkward and I question their intactness with time. I’m considering a standard 2×6 24″oc with a twist.When 2 framing members touch 1 of them is a 2×4 flush to the inside. You never let 2 2×6’s touch. This gives you a 2″ air space between the back of the 2×4 and the exterior sheathing. Now we fill the cavity with foam- including behind the 2×4. This eliminates air infiltration that would occur if we had 2×6’s adjacent to one another.Good idea? Bad idea? Yes, I know this is an expensive design and no, “stress panels” won’t work because the wall is too broken up. Thanks for the feed back.
Video: Build a Fireplace, Brick by BrickRelated Stories
John,
If your worried about thermal conductance at the studs why not build a wall with staggered 2x4 studs with 2x6 top & bottom plates; that way the studs won't carry through from one side to the other and you can weave your insulation around them. Also, consider adding a layer of rigid insulation (extruded poly styrene or poly-isocyanurate) to the exterior face of the wall between your sheathing and your house-wrap/infiltration barrier. This would be between your sheathing & your siding. I design buildings this way and have several up for very cold climates where the client is seeking optimal thermal properties with what is still basically standard framing.
Is the following wall design good or bad? I'm looking for a tight wall with no air infiltration. I'm not nut's about poly.,ADA etc. they seen awkward and I question their intactness with time. I'm considering a standard 2x6 24"oc with a twist.When 2 framing members touch 1 of them is a 2x4 flush to the inside. You never let 2 2x6's touch. This gives you a 2" air space between the back of the 2x4 and the exterior sheathing. Now we fill the cavity with foam- including behind the 2x4. This eliminates air infiltration that would occur if we had 2x6's adjacent to one another.Good idea? Bad idea? Yes, I know this is an expensive design and no, "stress panels" won't work because the wall is too broken up. Thanks for the feed back.
