should interior side of exterior window casings be primed or painted. getting conflicting advice. have tyvek over plywood sheathing and then exterior is cedar clapboard
Listeners write in about saving frogs, attic ductwork, lime wash, and energy ratings for real estate.
knowlege -
I certainly hope that you backprimed the cedar which will break down the Tyvek in a surprising short time. Yes on backpriming window casings - there is no reason not to other than the cost.
*Yes, the reason is that you want the same coating and resistance to moisture getting in or out all the way around. Otherwise, one side will expand or contract differently than the other, and the piece will warp.-- J.S.
