exterior wood finish??
bsh6979 | Posted in General Discussion on October 23, 2008 04:09am
I’ve just compleated 3 sections of railing for a gaz, the catch is, The panel are mahogany but they are pierced relief of a tree. they are for show only, they do have some roof cover but in the northeast they will be battered. was wondering what type of finish would be best, the cust. dosn’t want anything with a gloss.   Would danish oil be a good finish????    thnks
  1. andyfew322 | Oct 23, 2008 10:33pm | #1
    bump
    I'm just sayin'
  2. frenchy | Oct 23, 2008 11:35pm | #2
    No!
     Danish oil will quickly be gone providing no protection at all!
      Here's the problem.. all good clear finishes have a measure of gloss. The only real protection will be from a paint..
       I know! But all the exterior timbers on my place are black walnut and trust me I've done so much reseach on this subject I could write a book.
     Next best is a marine spar varnish.. The best one is a brand called Eppiphanes.. when you look at the price though it will really make you swallow.. then read the instructions on the side of the can and  that will really cause you to gulp!
     Other brands such as interlux etc.. aren't as durable but they are a fraction of the price.. Only one marine spar varnish to really avoid and that's Minwax's offering.
     Your best chance to get any sort of durability on this is to give it a coat of shellac first..  then a brief sand with 220 grit paper to simply knock off the nubs that are raised from the shellac.. followed with a second coat.. let that dry an hour and apply the spar varnish over that..
      The more coats the greater the protection. However about 5 years is the absolute most you can expect even using Eppiphanes with 5 or six coats.
  3. Shep | Oct 24, 2008 01:19am | #3
    The problem with any exterior finish is that UV rays will degrade it over time. And once the finish is degraded, then the wood starts going.
    A solid paint offers the most UV resistance, but that's obviously not an option.
    Choose a marine varnish with a UV protector. And one with lots of resins, to maintain flexibility.
    But if you get 3-4 years out of it without having to re-coat, you'll be doing well.
    Let your customer know that as soon as the finish starts hazing, or the wood gets gray, its time to re-coat.
    Sphere | Oct 24, 2008 01:44am | #4
    Better yet. Treat it like a boat. West Systems System 3 Epoxy with a SATIN Spar over. The Spar slows the UV degradation, but the epoxy will maintain the wood WHEN the Spar fails, not if.
    Being as most don't catch it in time, or properly keep up on it, the epoxy buys you (them) some saturated fiber time. That keeps the water at bay while the spar is being reapplied.
    Jamestown Distributers has EVERYTHING you could want.
    http://www.youtube.com/watch?v=Dj_oEx4-Mc4
    1. Shep | Oct 24, 2008 02:07am | #5
      Never thought of that.
      good idea!
    2. bsh6979 | Oct 30, 2008 02:00am | #6
      sorry about not getting back sooner, thanks for the information.
A Practical Perfect Wall
  • The New Old Colonial
