Extra Large Custom Fireplace
| Posted in General Discussion on February 27, 2003 07:41am
A client wants to build some very large custom fireplaces. The largest will have a fire box 8 feet long and 6 feet high. Floor to ceiling height is about 30 feet. He desires a masonry box and structure with stone veneer. He wants the option of using a gas log (Where can we find an 8 foot long gas log?) or removing the gas log and burning wood. He also is interested in having a heat recovery chamber type of flue, similar to what Tulikivi offers. I am looking for suggestions for design and materials. It is critical that the fireplace draw properly. Does anyone have any sources for design and materials of a fireplace with this description?
  1. booch | Feb 28, 2003 01:28am | #1
    Wow!
    That is one monsterous flue! A 36x36 face on a Rumford yields a 13 inch square flue. If opening to flue is directly proportionate then you are looking at a 20X30 flue. Lots of air whistling up that baby.
    Hopefully it isn't anywhere that really needs heat generation. Then again the servants that can carry 8 foot logs in to stoke the fire will be warm long before a match is lit.
    There are sources to consult and here is one... http://www.rumford.com/
    http://www.rumford.com/R9660plan.gif  is a 96 inch wide plan.
    96" gas log? You are on your own.
    Jack of all trades and master of none - you got a problem with that?
    1. Kayto | Feb 28, 2003 04:42am | #2
      Thanks for the advice. I'll check out the sites you suggest.
