Extra wide door sill /threshold extender
darnpotter | Posted in Construction Techniques on June 22, 2021 01:57pm
Referencing the article about installing exterior doors in extra thick walls… https://www.finehomebuilding.com/project-guides/windows-doors/doors-in-thick-walls
Our house walls are solid 8″ block with 2×6 framing inside. So if I install the doors on the interior to allow for a full 180″ swing, the total sill/threshold would need to be 12-13″ wide.  I’m not finding any sill extenders wider than 5″. Does anyone know of an alternative?  Thanks!
  1. florida | Jun 22, 2021 03:48pm | #1
    Your sill doesn't need to be that wide. The typical door jamb for your wall is 4 5/8" wide and the sill will be the same width. Sometimes when we run into flooring that doesn't come up to the new sill we'll use a 1 1/2" sill extension and on very rare occasions we'll use one for the same reason on the outside. If you have a concrete floor just leave the concrete exposed and it you have wood use some break metal over the edge and under the sill.
  2. calvin | Jun 23, 2021 05:58am | #2
    Depending on the transition between the block and interior floor height I have used a limestone “threshold” on top of the block with a regular sill extender lipping over the transition. The limestone extends over the face of the block an inch and a half.
    1. florida | Jun 24, 2021 02:58pm | #3
      Haha! I went to a condo today to measure for a new entry door and bless Pat if the "sill" wasn't 14' wide! It was a make-up job using parts and pieces of the original sill plus at least 4 and maybe 5 others!
Versatile Vise
