Faced or Unfaced batt insulation in basement walls?
RE10 | Posted in General Discussion on September 7, 2023 11:26am
I am finishing my below grade basement. I put Owens Corning R-5 against the slab walls. Now my question is do I put faced or unfaced batt R-15 between stud spaces on the exterior walls?
  1. pkrivanec711 | Sep 08, 2023 09:40am | #1
    If you taped and sealed the R-5 rigid insulation, then you do not need faced batt insulation. I believe your intent is to use the R-5 to prevent conditioned air from hitting the cold surface of the foundation wall. The best way to achieve this is by taping and sealing all the seams of the R-5.
    I attached an article that will provide some more insight to what I'm saying above. Good Luck!
    File format
