Fake Brick Substitutes
FlavaDave | Posted in Construction Techniques on July 16, 2006 01:07am
I would like to discuss any positive fake brick or thin brick alternatives out there.  Anyone had good luck with flooring, exterior wall, or interior wall faux brick finishes.
Sometimes the photos look pretty good, but I don’t have any experience with this.
Can you recommend a manufacturer?
  1. Brian | Jul 16, 2006 01:25am | #1
    I have a friend who sells & installs brick for Redland Brick (Cushwa plant, western MD) They attach a metal track to the house, click in real (thin) bricks and point with regular mortar.  Looks exactly like the real thing, and you can do keystones, flemish bond, shapes, angles, whatever you want with whatever color real bricks you like.
    Its not much cheaper than regular brick, except you don't need footers or masons, and can brick your dormers if you like...
    I forget the name of his product - if you are interested I can look it up.
    Treat every person you meet like you will know them the rest of your life - you just might!
    McDesign | Jul 16, 2006 03:31am | #2
    Well, I guess real brick would be a substitute for fake brick!
  3. HammerHarry | Jul 16, 2006 03:41am | #3
    Many years ago, 3M had a product which essentially consisted of a thin, grey drywall mix that you put on the wall; then you taped off a brick pattern with 3/8 wide tape, and put a 1/8" layer of red on top...let it set for  a while, then pulled the tape off...it looked surprisingly good.  Long gone product, though.
  4. Jer | Jul 16, 2006 02:56pm | #4
    Absolutely have used veneer real brick with great results.  Goes on like quarry tile with a thinset, walls floors, chimneys, exterior and interior.  You strike off the joints like regular brick.  If installed by an experienced brickie or tile setter you cannot tell the difference.  All it is is real bricks that have been sawn to 1/2" thickness.  When I put in my woodstove (one of these years) I intend to build a box around the ss chimney and veneer brick it to look the same as the existing chimney.  Like mentioned above, no footers or fondations need apply!
    Sorry I don't have a link right off hand.  Will look about and see if I can get it for you.
  5. Ray | Jul 16, 2006 04:59pm | #5
    Z-brick looks good as interior decoration on a wall or fake fireplace.  Use the 'net or check with Ace Hardware.  It uses a mortar-colored adhesive and is pretty easy for a homeowner to install.
  6. mackllm | Jul 20, 2006 12:40am | #6
    A couple of years ago I did my foundation.  Bought full size bricks and rented a wet saw.  Cut them to 1/2" and glued them with construction adhesive and then pointed the brick.  The only trick is the corners but I was able to cut and L shape with the wet saw.  Can't tell it is only a thin veneer.  A lot cheaper then buying already sliced then bricks.  Only thing is I thought I could get two faces but brick I bought had a diffferent texture on other side.
    1. roxanna | Jul 20, 2006 03:11am | #7
      just out of curiosity, what did you do with the scrap leftovers??
      1. mackllm | Jul 20, 2006 05:32pm | #8
        Still have them piled up in my shed.  Looks like they may become fill.
  7. Vander2295 | Mar 07, 2014 07:18pm | #9
    fake brick
    Can you provide me with info about the brick for houses that dont have a foundation for brick
  • A Postwar Comeback
