never thought I’d be excited about garbage cans …
I went on a search a coupla months ago for the “perfect” garbage can … and settled for the typical big ol’ Rubbermaid Rough Neck…
so …
as all my crap is in the van … or on the current job site …
as I was working out of the pick up and tending to a small job … I realized I needed some more cans for that small demo job …
and figured I’d buy “pick up sized” as opposed to the “van sized” I already had….
why by what I already had, right?
So I got 2 smaller 20 Gal Rough Necks …
and I’m really glad I got them.
Narrower … easier to grab … easier to get thru doorways and down steps …
and ya never fill the big ones the whole way up anyways .. because ya can’t pick them up full … so the little ones still hold the same weight.
I’m gonna go back and get about 10 more.
Artistry in Carpentry
Yes, the layman underestimates the true value of a perfectly chosen refuse receptacle.
rg
Only someone who appreciates the simple pleasures in life can do this kind of work. I mean, do you think an investment banker ever rhapsodizes over a garbage can?
Al Mollitor, Sharon MA
Man Jeff, I've got ALOT of cool RuberMaid garbage cans, but if your THAT excited about a Rough Neck I better go check them out.
I don't know what can fills the quickest, the one for pop cans and lunch garbage or the the one for scrap. View Image
Bob
you my friend...
are way to easily amused.
I used to have a 20 which fit inside the 35 which fit inside the 45. After a while, no one touched the 45 any more. Takes a big boy to handle that all day. They are great cans. They aren't indestructible though. Dropping them, even empty from just 6 feet up on scaffold on a Pittsburgh January day, will crack them. My biggest problem is the circular saw blade cuts through the top edges from the bums who bypass the horses for a "quick" cut.
carpenter in transition
>> My biggest problem is the circular saw blade cuts through the top edges ...
Maybe you could add an inconspicuous steel reinforcing ring to the rim. I bet nobody would cut into it twice.
unfortunately, they would do it with my saw, with my blade.......
my name is mitch, and i get a little charge out of a quality waste receptacle, too. just wanted you to know you're not all alone out there man... and yes, roughnecks are my faves.
m
Just today used two of them as saw horses...
I made sure I laid a scrap of 2x ...ok..it was actually 3x left over from some of the clients shipping crates ..... across .. and I actually checked the saw depth twice before I made the cuts!
I'm thinking way too much about some garbage cans!
CAG was right.....
Really .....it's the simple things in life .....screw those investment bankers ...
probably why my wife's boss misses so many sick/stress days ...(investment banker!)
He's got no really good trash cans .....
Jeff,
If you are into trashcans---ya need to get rid of those Roughnecks from rubbermaid---and Upgrade.
rubbermaid makes a line called BRUTE---which seem to be 2-3 times a thick as the roughnecks.Man,oh,man are they heavy--even when empty---but they take abuse like you can't believe. they are pricey---$40 plus a piece I believe----but they last forever.I have 3 of 'em on my truck right now with over 160# of shingle scraps in each one.
My dump guys ( subs) call 'em Steve's 500# trashcans.
BTW---I had help from a FHB editor lifting these last 3 into the truck. Imagine---an editor doing heavy lifting?Dan Morrison lifted his end real well---even for a skinny guy!LOL
The Brutes are what my full size cans are ...
these 2 new ones are like little mini Brutes ...
Next time you're stocking up on Brutes .. see if they have a 20 gal size ...
You'll love them!
ya know what ? my cans are the Brutes, just like Shaz mentioned ! i forgot about that. i hate to tell ya, but the Brutes are definitely one up on the standard can
have a look
http://www.sanitarysupplyco.com/71610200.htm
Well, since you asked...
I have found this tub:
http://checkoway.com/url/?s=e59d6d1b
very useful. They sell them at the box stores. They are tough (I think they are about the same thickness as the super HD cans that SHAZLETT was referring to) but not too big or bulky. They are great for carrying tools from the truck to the job area, they work well as a small trash can (great for demoing dense material) and don't take up too much room in the truck. I have seen my fair share of trash cans that have torn handles, and these tubs use a rope loop from the reinforced lip.
I appreciate a clean job site, so I also appreciate a well made trash can. Good thread.
Jon Blakemore
Im back to trying to work . I cant lift near as much as before , so I guess Ill go shopping. Thanks for the tip. 20 gallons sure sounds light.
Tim Mooney
I being the weakling I am can only handle two joint compound buckets when hauling out debris...wish I were a roughneck!
Me, too. Two 5 gal buckets of old plaster about maxes out my load carrying ability. Their other advantage is that you can walk thru between studs on 16" centers with them.
-- J.S.
I have the same warm place in my heart for getting stuff out -- and I am always stopping along the road becaseu there are always a few cans that blow out of trucks and you can never tell when you are going to need on and just leave it there -- wife thinks I'm crazy.
I leave the big ones on the truck and fill the smaller joint buckets and then fill the larger ones -- I too, can handle the 5 gallon sizes but not one of the biger ones filled -- handles always seem to break off -- this way I just slide them in the bed and tip them at the dump -- no muss no fuss. All the best Dudley
