Fantech exterior mount kitchen exhaust
k1c | Posted in General Discussion on November 29, 2012 01:40am
Hello.  Fantech makes an exhaust box that mounts on outside wall.  I’m looking into this because motor can’t be found to replace the original that is worn out.  Motor repair shop can replace the bearing, but can’t say how much longer it will work.
I like to keep this hood.
Fantech rates above exhaust for 140 degrees F., but I have doubts if 140 degrees is enough for kitchen range exhaust.
Is anybody using this and having any temperature cut out problems?
Thank you in advance.
  1. calvin | Nov 29, 2012 08:42pm | #1
    I've put in a couple of Thermador exterior exhaust fans-both for an indoor grilling system.  Never thought about (was directed to install and approved by inspection) the thing, know nothing about temp rating, but...........
    If they still make them, check into their spec's.
    or
    I've had some good luck talking with the tech's at Fantech.  I'd give them a call with your concerns.  I don't think they'd steer you wrong to make a sale you won't be satisfied with.
    Remember, room air will mix with the heat over the range.  That very well could temper it below that 140 you think you might have.
Drafting the 2027 IRC
  • The New Old Colonial
