Whats the best way to get mud to dry in a garage? The walls are drying well its the corners that arent drying. My buddy wanted to just to turn in the torpedo heater for a few hours but I feel this will dry the mud out to rapidly and crack it( I have observed two cracks in butt seams). My guess would be a dehumidifier would work better. Anyone have experience with this situation. I’m working in Michigan and its getting into the forties at night around here.
don't put it on so thick....
give it time...
WOW!!! What a Ride!
Im in Lansing.
Try a setting mud. Maybe 45min or 90 min. It will probably set up quicker then you expect. I would use 90 min.
Rob Teed
I've always found 20 min to set up in the pan ...
and 45 min to set up sometime after I get tired of waiting and go home for the night.
Pickling alum speeds it up.
Cream of tarter slows it down.
wont work on regular mud tho. just on setting type.
How much cream of tartar do you put in a bucket batch and does it double the time?
rg
You just have to play w/ it. What I have done is put the c/t in bucket, then put alum in the mix on my hawk. mix quick & work fast. kind of like salt & pepper w/ the alum. I put the c/t in the water when I make my mix >> baybe a tbs. the more u use, the slower it cooks. I work too slow to use 20 min. so i usually get 90, slow that down & speed up what is on my hawk.
Martha Stewart had that very recipe on her last show prior to heading to the penitentiary. I don't remember the exact measurements, but she did recommend garnishing it with an orange slice.
"Kerry/Edwards": A campaign so full of cr*p that they needed two johns.
What is pickling alum. and where do you get both of them.
alum is a white spice used to make sweet ( i believe) pickles out of cucumbers. find both in the spice aisle at the grocery store. An old plasterer taught me this one. Works w/ setting compounds, plaster, and I assume most any portland cement product.
Oh, BTW...drywall mud will be prone to crack if temp gets below 55.In an
unheated garage expect cracks.
We run heat and fans. You don't want to aim the space heater right in the corners. I have a thermostat and set it for 75-80. Good air circulation makes a big difference.
LaFarge makes a drywall mud that dries fairly quick and is easy to use. Available at Menards.
Corners take a long time to dry , so dont get worried .
If you have a dehumidifier use it , but cracking the windows or a door a bit and running fans will take the moisture "out side". Its hard to dry anything with out ventilation. The temp is not too cold , it just takes longer . Do not put a turbine blower on it to dry becuse it wont . It makes moisture becuse its not vented. You just use those things to work in the day time to stay warm. Windows cracked 3 inches or a door is good with fans down to 20 degrees . Ive never saw a bucket of water freeze in a house down to 0 degrees at night as long as the job was heated in the day time. The walls retain heat .
But honestly with temps 40 and above , OPEN THE GARAGE DOOR. Thats it , then you can warm it up the next day. If you have vesqueen over the door opeing , take it loose at the bottom and open the walk through door.
I probably wouldnt do anything the way it sounds. You have all the flats and butts to work on two or three coats and only one coat in the corners last thing . Youve got a while before you are in the corners again. Dont sweat it .
Tim Mooney
Hey Tim, thats about what I was thinking. Its all about moving the moisture. All the rest of the walls are done and now the corners are close too. I had the garage doors open all day yesterday and the walls dried fine. Thanks to all.
