fasteners for 3/4 pine dutchlap
cwcjr09 | Posted in Construction Techniques on June 20, 2012 05:48am
Hi All,
What are the best fasteners for installing 3/4 pine dutchlap siding? I am rebuilding a wall where the previous builder used 2 1/2″ galvanized finish nails – I know that’s not right/substantial enough but they have seemed to hold up surprisingly well.
What is the best technique / location of the fastener? I have read some articles which recommend nailing an 1 1/2″ up from the bottom of the siding a little above where the siding piece and the piece below overlap – but definitely not throuh both at the same time.
Thanks for the advice.
  1. DanH | Jun 20, 2012 08:22pm | #1
    "Galvanized finish nails"
    "Galvanized finish nails" would be casing nails, which probably are adequate.
    MarkH | Jun 21, 2012 07:18am | #2
    Your nailing advice is correct.  I would use Maze S227A “SPLIT-LESS”® WOOD SIDING NAILS (if you're hand nailing).
Outdoor Lighting
  • A Postwar Comeback
  • Natural Simplicity
