Fasteners for decorative fascia trim?
What type of nail should I use for the solid pine trim that I’m putting on my fascia boards? Also what should I use to hold the outside corners together? Adhesive?
Something I did a couple of times is using biscuits and good water proof glue. You just have to use care in measuring, and the large size biscuits, 20's i think. Another slick way is a Miller Dowel system . Uses a stepped drill bit and different size dowels. Woodworkers supply should have them. I used them when i build furniture and they hold real well.
Thanks CB. I don't have the tools to do the biscuits.
Is this interior or exterior?
Regular finish nails should do just fine, set and puttied to match the wood. If exterior, use galvanized. Don't use hardened trim nails, they're too skinny for soft woods like pine.
I like Titebond II for most of my wood gluing. Outside corners you might want to cut and glue 'em up before installing, as oftern done with crown molding.
~ Ted W ~
Cheap Tools - BuildersTools.net
See my work - TedsCarpentry.com
Thanks Ted. Exterior. Should I use 6d or 8d galvy finish nails?Never thought about gluing corners before putting the trim up. Good idea. Does the glue work on painted surfaces?
For exterior I would do what redford says. Finish nails for interior, but box (headed) nails for exterior. Try to get the 'Double Dipped' type. If the box doesn't say so, you can tell because the galvanized surface is rough and bumpy. The paint will cover the nail heads.
Gluing is for outside corners, which I would also nail, but predrill first or it will split for sure.
"Does the glue work on painted surfaces?"
With a new cut that shouldn't be an issue. I differ with redford in that I miter cut running joints, It's more work but hides the joint better when it opens. But I agree with him about priming and painting them, no caulk. It's assumed these joints are going to open no matter what, anyway.
~ Ted W ~
Cheap Tools - BuildersTools.netSee my work - TedsCarpentry.com
Edited 3/1/2009 8:21 pm by Ted W.
If hand nailing, I use an 8P galvy box nail. I think setting and trying to patch finish nail is an exercise in futility. Finish nails lack a decent head to keep trim boards from cupping and pulling away.
Also, I don't miter exterior trim boards, just butt cuts, primed and painted after cutting. Thus, no need to worry about joints opening up.
Thanks guys for all the help.
I thought we covered that already?
Not for the trim, just the fascia. I forgot to ask about the trim.
Same nails!
Full round head for trim? Chair rail trim?
Thought you were outside still. Inside I use a 16 guage nailor for everything<G>
I got a sinking feeling he is using pine chair rail for shingle mold.
As long as its all back primed and either glue/or end primed ( not both) it should last a while. I've taken to Azek for that for permanence.Spheramid Enterprises Architectural Woodworks
We has also, but as he lives in Texas, he might get away with the pine. I have used pine on my shed, but I made sure 6 sides were welll primed first!
I am still outside. I am using the chair rail as my trim for the fascia. Solid pine,primed and painted on all sides.
In that case you could use either the 16 guage if you have a gun or headed galv or stainless nails. On the outside I have never glued the facia or trim at the corners. First I am not sure it is a good idea, as the ouside gets considerably more moiture than does the inside.
Second, trim on the outside is not held to the same standards as inside trim!>G<
Are box "headed" nails similar to cut nails?
No, BOX nails have a thinner shank, they prevent splitting better.
Cut nails are the not round ones, and never galvanized or stainless and totally not what youd want, unless you are nailing into masonry. Even then, they are rather archaic. I use them decoratively or in instances where it is fitting when nailing into my hard as hell logs.Spheramid Enterprises Architectural Woodworks
Thanks Sphere.
If you are hand nailing, I always use the brand name of Maize nails, they are ring shanked and very thin. Made for exterior applications.
Here is a place to buy online.http://www.mcfeelys.com/category.aspx?cat=maze-nails&s_kwcid=maize%20nails|2641568395
So in reality a full headed nail is just fine for exterior trim. I was thinking I needed a galvy finish nail.
Yep
