fastening a wall over laminate flooring
I have a client who cant sell their house because the Washer dryer are right next to the fridge. She wants to enclose both with a few walls and a bifold door. Her kitchen has a floating type floor. If I secure the walls right over the top of it I eliminate the need for flooring the enclosure, however I am worried the floor wont expand and contract correctly. Should I be concerned. The area in question will be about 6x 3.
Never had to do it but I'd be thinking of the several hundred pound filled frig over there in the corner. And if concerned beyond that I might come up with a way of hanging these couple new partitions, perhaps slotting the fastener through the lam for the bottom plate connection.
http://www.quittintime.com/
My guess is that the flooring is not going to expand much, since it is not solid wood. It is probably made of plywood or mdf, and both are more stable then solid wood. If you are concerned, after the walls are framed and before the sheetrock is hung you could use a MM and trim the laminate 1/2" off the framing, which would be covered by the rock and base."Put your creed in your deed." Emerson
id be tempted to nail/ screw the bottom plate right through the flooring. you could always trace the flooring and cut it out. tip, trim nail the flooring in the ends of a couple boards first as some of those floor boards will slip/ slide side ways when the pieces are short. even on a long run i wont hesitate to pop a finishing nail into the board end close to the wall to keep it secure.
id just go right through it.
Double stickem tape. It aint gonna move that much.
Mike
Small wheel turn by the fire and rod, big wheel turn by the grace of god.
Just nail it, it'll be fine. I've done it before. You could always cut around the plates later if need be. My $0.02
I'm no expert, but I've seen the results of floating floors that weren't installed with sufficient room for expansion/contraction. It's not a pretty sight.
I think your concern is legitimate, but there are a lot of variables like what it's installed over, geographic location, size of the floor, expansion/contraction gaps at the other ends of the floor, etc.
I would be dis-inclined to do it because if it doesn't work, the fix might mean re-installing the entire floor. If you decide to do it by cutting around the new walls, be sure that the floor can still float through the new doorway as well.
i think it is good to keep the existing floor in place and frame over it, makes for a neater and cheaper job
if you are concerned about floor movement you could use as few fasteners as possible to attach the new bottom plate, toenail the rear of the new bottom plate to the existing wall, toward the front of the new bottom plate, drill a 1" hole in the laminate flooring and screw the new bottom plate through the middle of the hole (just snug enough to hold it in place, but loose enought to allow expantion and contraction of the laminate floor)
I have only built something over a floating floor once... and it bit me in the hindquarters. I just ran a small peninsula out over a laminate floor (see photo). The floor, even with a proper vapor barrier under it, buckled up on both sides of the peninsula during the humid part of the year. I had to go back and cut the flooring loose all the way around the base cabs I had set on the floor--PITA.
Since then, I always remove floating flooring before installing anything. I also maintain a proper expansion gap around the installation.
I say cut it out!
I concurr with Fast Eddie. Cut out around the plates a half-inch both sides.
Gives ya a good excuse to finally buy a FMM anyway. Me, I'd use my jamb saw and hang on real tight.... ;o)
Dinosaur
foolish men call Justice....
here is an idea
