Faswall, Durisol form blocks
| Posted in General Discussion on October 12, 1999 05:55am
has anyone had experience with The woodchip concrete form blocks that can be used as basement walls when poured with concrete and reinforced with rebar? I have seen them in a project and they look promising but before shiftimg from regular poured walls and rigid foam insulation I would like some more feedback. Thanks
  1. Ian_ICF_Builders | Sep 26, 1999 09:50pm | #1
    They work, but must take extreme care in installing, and placement of concrete. They must be WATERPROOFED, not just coated with black tar emulsion, otherwise you could end up with an indoor swimming pool...... For more info, go to insulatingconcreteform.com and click on ICF TALK. Consult a local engineer as well. LOL
    1. John_Beck | Sep 28, 1999 03:17am | #2
      *IanCan you explain what you mean by extreme care? How do they differ from polystyrene?
      1. Ian_ICF_Builders | Oct 12, 1999 05:55am | #3
        *The Faswall blocks are highly susceptible to moisture damage, they must be kept DRY and stacked well, they also can have problems during the concrete operations, since they don't give warning if you have broken block.
  2. Boone_Guyton | Oct 12, 1999 05:55am | #4
