favorite paintable wood filler?
merlvern | Posted in General Discussion on September 18, 2008 04:46am
i feel like i’ve tried everything!
i’m building more built-ins, that i will paint after i fill the nail holes and some seams.
i’ve tried paintable caulk, wood filler, both acrylic and latex, and i just can’t find something i like. i suppose if i had something that worked like drywall compound, but didn’t shrink or slump, or if i had something that spread like latex paintable caulk, but sanded well,…..
any ideas? whats your favorite
thanks in advance
  1. Hiker | Sep 18, 2008 05:10pm | #1
    We have gone to bondo on all critical applications.  I have had several problems with filler failing and not filling well even after a second application.
    Bruce
    1. merlvern | Sep 18, 2008 05:18pm | #2
      bondo? as in for cars?
      interesting. does it have flexibility? for instance, bump the bookcase during transit, will it "pop" out? like some fillers do.thank you,john
      1. Hiker | Sep 18, 2008 06:32pm | #4
        Never had it pop out.
      2. splintergroupie | Sep 18, 2008 06:37pm | #5
        Bondo's amazing stuff. If you need it vertical, you can clamp a board against it, with a piece of wax paper between. When it's cured, you can take the formwork away and peel the waxed paper right off. I've used it to replace hinge gains when i've changed a door out for one with different hinge placements. After painting, the repair is invisible and holds, even on a door.
        You can also tint it darker with artists' colors for stain grade on darker woods or...i just use the goop from the bottom of a can of oil stain with a bit more catalyst. WHAT THE PUCK???
    PeterJ | Sep 18, 2008 05:40pm | #3
    Putty Cote, although there are other brands. Very similar to Bondo, but finer texture and feathers better. Needs to hook into something like any other putty, I"ve done some pretty amazing repairs, like replace whole corners of cab doors. As far as I know, no failures.
    Handles a lot like drywall mud, but catalyst is something to get used to. Ten degree ambient can make a big difference in "go off" time. Figure on having some set before you want it to, just mix more.
    Odor really bugs some people, I've cleared houses without intending to. Now I warn people.
    http://yhst-13811118617756.stores.yahoo.net/dypu5pogland.html
  3. canoehead2 | Sep 18, 2008 11:11pm | #6
    Another vote for Bondo!  Bonds well.  Rock hard.  No shrinking.  No pop outs.  Nice to sand.  Takes paint well.  And, best of all, you can prime after about 30 minutes.  Just be fast about it - you've got about 3 minutes of workability.
    1. merlvern | Sep 18, 2008 11:21pm | #7
      bondo it is!thanks everyone,john
      1. Grantdawg | Sep 19, 2008 12:35am | #10
        I really like Sherwin-Williams brand wood filler--dries really hard, sands pretty easiliy, doesn't shrink and don't get many voids.
      2. reinvent | Sep 19, 2008 02:29am | #11
        Buy an extra tube of hardener. Everybody mixes in more than they should.
        1. Piffin | Sep 19, 2008 11:55pm | #20
          Not everybody. I have tubes and tubes leftover
          1. reinvent | Sep 20, 2008 01:40am | #21
            Thats because you are an old seasoned yankee.=-?
  4. square668 | Sep 18, 2008 11:32pm | #8
    Durrams (sp?) water putty.
  5. Piffin | Sep 19, 2008 12:19am | #9
    easy
    Minwax Wood filler
    1. unTreatedwood | Sep 19, 2008 06:48pm | #19
      I agree!"The nearest thing to eternal life we will ever see on this earth is a governmental program"  -Ronald Reagan
  6. DonCanDo | Sep 19, 2008 04:16am | #12
    I think Bondo is overkill for interior wood fill (I'm assuming interior since you said built-ins).
    I just use lightweight spackle for nail holes (no shrinkage and sands easy) and for larger holes such as screws, I use pre-mixed wood fill if I have the time to hit it twice otherwise Durhams water putty.
    I think I would just use caulk on the seams since that seems like a likely place for seasonal movement.
    1. merlvern | Sep 19, 2008 06:28pm | #17
      thanks don,i've found that the light weight spackle "pops",.....you?
      1. DonCanDo | Sep 21, 2008 11:01pm | #29
        Yes, I've noticed that too.  Not always, but usually.  I'm not sure what causes it, but it's not a problem.  In fact, it helps to ensure that the hole is sufficiently filled.
  7. DougU | Sep 19, 2008 04:57am | #13
    I'll use bondo on big stuff but for nail holes I wouldnt bother, Crawfords is the way to go.
    Crawfords doesnt shrink and sands really nice. I apply it after priming.
    Painters that we use on occassion will mix a little tint into the Crawfords so that they can see the filler easier. Great stuff.
    31904 QT CRAWFORD SPACKLING
    Edited 9/18/2008 10:01 pm ET by DougU
    1. Fishrite | Sep 20, 2008 10:44pm | #28
      I second using Crawford's.  I love that stuff!
      Easy to use and clean to work with.
      I usually buy the smaller 14.5 oz. container.  (It's plastic.)
      "Everyday we learn something new. Take life as a test and shoot for a better score each day. It doesn't have to be an "A" the next day, but let's hope it improves." 08/27/08
      Matt Garcia 1986-2008 22 yo Fairfield City Council Member, shot 09/01/08 RIP
  8. VTNorm | Sep 19, 2008 05:47pm | #14
    http://advancedrepair.com/
    Overkill for just filling nail holes but it's da bomb for repairs and larger gaps. No slump, sandable, paintable, can be tinted to match stains, will hold nails and screws, can be chiseled or worked with tools...
    A little pricey but for the right application it's worth every dime.
    -Norm
    1. rasher | Sep 19, 2008 06:04pm | #15
      I use ALEX 230 for all joints between separate boards and materials. I use Elmers Wood Filler for nail holes and small voids. I've never used Durham's Water Putty, though, but I suppose I'll give it a try after reading all of the glowing recommendations...
      1. und76xx | Sep 19, 2008 06:12pm | #16
        This will not work on seams but works GREAT on nail holes. Take a little wood glue - you favorite choice. Saw a little of the wood you are about to fill the nail holes and mix until you have toothpaste. You need the saw-dust for shrinkage - or lack thereof.Mike
    2. merlvern | Sep 19, 2008 06:29pm | #18
      thanks everyone
  9. RedfordHenry | Sep 20, 2008 04:01am | #22
    My current favorite for paint grade work is H. F. Staples Miracle Wood Filler.  I looked at the MSDS and it appears to be a blend of alcohol, acetone, and wood dust.  Dries hard and sands well, although I usually need to touch up the hairline gaps around the edges of whatever holes I have filled.  I have filled many 3/8ths inch counter sunk screw holes.  After filling and painting, the patches are invisible.
      mmoogie | Sep 20, 2008 05:34am | #23
      Another vote for bondo. Cheap, hard, sticks to nearly everything, sands and feathers well, though you have to change the paper a lot. Bondo even started selling it in a different can and calling it "Home Repair filler" or some such nonsense, and charging 10% more than for the can of plain old bondo sitting on the shelf right next to it.Minwax is OK too, though I suspect it's pretty much the same thing as bondo at twice the price. And I hate the white catalyst. I guage the hardener by color , and with the red hardener I can make the tube go well beyond a can. With the white I always feel I need more hardener for some reason.Steve
        Sphere | Sep 20, 2008 03:29pm | #24
        Since I was 14 and helping in an auto body shop, my rule has been "A glob the size of a golfball, gets a glob the size of a pea"
        I just adjust slightly for cold/warm days, and can also kinda wing it when dealing with big quantities.Spheramid Enterprises Architectural Woodworks
        http://www.youtube.com/watch?v=Dj_oEx4-Mc4
        The world of people goes up and
        down and people go up and down with
        their world; warriors have no business
        following the ups and downs of their
        fellow men.
  10. highfigh | Sep 20, 2008 05:16pm | #25
    As said, Bondo is one of the best. If you shop around, you'll see a pretty wide range of prices and Home Depot, etc sell it in gallons for less than I have seen at auto parts stores.
    If you ever need to sand odd contours or moulding, get a 1 qt sandwich bag, put a good amount of Bondo in it and press it down, so it fits the contours. Let it set and remove any sticky resin. Press your sandpaper in and if you want, you can remove a little from the valleys to make sure the peaks aren't rounded off.
      mmoogie | Sep 20, 2008 05:32pm | #26
      >>If you ever need to sand odd contours or moulding....<<That's a great idea! You should submit that for a FH magazine tip...Steve
      1. highfigh | Sep 20, 2008 06:33pm | #27
        Too late- I got it from Jeff Jewitt at the Woodworking Show a few years ago when I went to the refinishing seminar.
    2. merlvern | Sep 23, 2008 04:10pm | #30
      great tip thanks!you know, i worked with bondo this weekend, worked well only, the frustrating thing when filling holes is that the material "rolls over" on itself and pulls the back part of the stroke out,......necessitating a second application. granted, the 1/2 hour setup time makes a second application easy, but i spose i was looking for the PERFECT filler :)one other problem with bondo, though a small one is that it sands less fast than the surrounding wood......got to be careful of surrounding.thanks for the help,john
        mmoogie | Sep 23, 2008 04:20pm | #31
        >> sands less fast than the surrounding wood......got to be careful of surrounding.<<I usually feather wide of the hole on the second coat, and when sanding, try not to sand the feathered part completely away...so that a screw hole will wind up with about a 1" round feathered patch of bondo...Also, that pulling out that you get on the backside...your technique will improve that...On the first fill, squish the bondo in hard so that it kind of quirts out behind the knife as you go. Also turning around and doing it again in the other direction right away sometimes helps too. But yeah, you pretty much have to do two coats to get it invisible.Steve
        Edited 9/23/2008 9:21 am by mmoogie
        1. merlvern | Sep 23, 2008 04:24pm | #32
          funny, takes a little technique for sure.....next time i'll get it just right.
      2. highfigh | Sep 23, 2008 04:31pm | #33
        It rolls over the hole because the hole is dry. Once it grabs, it fills. Bondo can be thinned, too but it's not usually necessary.
        1. merlvern | Sep 23, 2008 04:42pm | #34
          patience, patience, just got to get good at patience
