Does the Multi master work as advertised on TV or is it just another gizmo that falls short on expectations? I plan on using it to cut into wood. The plunge technique they showed on TV is what I would use it for the most.
Thanks Charlie
Thanks Charlie
Dangerous electrical work and widespread misconceptions cause fires, deaths, and $1.5 billion in property damage annually.
Try the search feature. The Multimaster has been discussed here quite a bit. I don't recall anyone having anything negative to say about it.
OK, I'll be the first to say something negative about it.They came out with the new model with that easy quick change gizmo right after I bought the old model so every time I spend 2-3 minutes changing accessories, I cuss myself for lack of foresight and research.other than that. it is a fantastic tool. I don't think I would have been able to do much of the work I've done the past couple weeks without it.
ya can't frame a house with it but it'll plunge thru wood like a hot knift thru butter.
hard, frozen butter ... but a knife thru butter it is.
Buck Construction
Artistry In Carpentry
Pittsburgh Pa
You forgot "dusty".
Hard, frozen, dusty butter.
Mike HennessyPittsburgh, PA
that too.
and much like pif .... I also got mine right before they came out with the new version.
and I blame Hubcap for giving me the old version for free ... the cheap bastdige!
Jeff Buck Construction
Pittsburgh Pa
Very inconsiderate of me...as to the value of the tool, in my opinion if Jesus would have had one no way does he end up paying for the sins of the world.Rather the " J.H. Christ and Associates Contractors and Salvation Specialists" would have been the toast of the empire! No emperor would dare crucify a carpenter who owned such a tool.and a skidsteer and maybe a laser level or two as wellI'm just sayinganywaysorry I gave you an obsolete model.buy the variable speed one CharliezNo Tag
I can't believe U did such a thing either.
with blades ... and accessories too.
U bastdige.
U really know how to hurt a guy ...
Buck Construction
Pittsburgh Pa
I gotta nasty disposition.No Tag
hey I forgot-I got one of those fancy pants stiletto hammers today.I can't wait to go out and pound some nails...it's got arrows on the handle so you know which way is upNo Tag
"it's got arrows on the handle so you know which way is up"
well ...
I can see you've corrected part of the problem!
Pittsburgh Pa
But even J. C. thinks a Kapex is too expensive...I work for a cheap carpenter.
"After the laws of Physics, everything else is opinion" -Neil deGrasse Tyson
If Pasta and Antipasta meet is it the end of the Universe???
J.C. may have a point.
I used the stilleto-
to put the lid on a can of stain.
it was effortless.No Tag
It'll plunge through till you hit a nail then it'll plunge through wood like spoon.
Its a great tool, excellent quality, with tons of uses that you won't think of at first.
For me, the only negative is the cost of replacement blades.
Politics is the antithesis of problem solving.
The blades do cost money,but for me, cost is relative.First - like any other job cost, the customer pays for it.
Second, relative to the cost of the labour involved doing the job without that tool and accessories, those blades are cheap. And they are good, lasting a long time
and there is/was someone on ebay selling a substitute bladeas well as a couple of threads on making your own.
bobl Volo, non valeo
Baloney detecter WFR
"But when you're a kibbutzer and have no responsibility to decide the facts and apply the law, you can reach any conclusion you want because it doesn't matter." SHG
finally broke down and bought one last week, $600 for a kit and 1 special blade!!!!
here's a link http://www.multiblades.com/ you should check out this guy sells replacement blades at a fair price for both old & new models of the multimaster. I've purchased ten at $160.00 mixed wood & drywall blades and got one free + free shipping a good deal and you have them in 4 or 5 days and he takes credit card or paypal . I've e mailed him about specialty blades for the MM he sent me an email that he is now in the process of selling them.
ZeeyaView Image
Zeeya
Is this the same guy that shut down sales a few months back after he was threatened with a patent infringement law suit by Fein?
I was just going to order when he shut down. IIRC the infringment was on the hole design, and if I look at the current web site he may have changed the hole. Is that what happened?
Rich
Rosy
Yes it's the same guy. Here's the e mail I received from AL on 6/21/08 and on 6/26 he reopened for business it will explain it all I hope this helps
Zeeya
Frank, Thanks for your request. I am still selling blades but I am postponing reopeing my site untilabout the middle of next week. The star hole this lawyer is complaining about was in existence yearsbefore Fein patented their star hole. My star hole is different and Iwill be sending this lawyer a copy of the catalog I have that showsthe star hole I use is not infringing on their patent. To prove that in court cost hundreds of thousands, I am in contactwith Fein's lawyer and I will be sending him proof that my star hole wasin use many years ago. I am happy to know I have proof now that my star hole is notinfringing on any patent. For the time being I am using a different hole, that works as good asthe star hole, until this issue becomes clarified. See the attachment. Next week my site will begin offering round diamond grit blades andtungsten carbide grit blades for removing grout and for other applications ata fracction of the cost compared to Fein's. If you still want to order some blades with the new hole you see inthe attachment go to my old page and order from there and remember thestar hole you see in the pictures is not the one I am using now. http://www.multiblades.com/none1.html Thanks for your request. AlView Image
It's a good tool, but watch out for nails - unless you are using the combination metal blade. Even then, I am careful to remove nails whenever possible to extend blade life.
One thing that surprised me is that I have used the scraper blade about ten times as much as I thought I would - almost as much as I have used the wood blades. That scraper has many uses and it can be easily sharpened.
Yeah, I've probably used the scraper more than all others combined. I wouldn't use it for removing the finish from fine furnature, but for jobs like removing bits of linoleum it's the cat's PJs.
It is an ironic habit of human beings to run faster when we have lost our way. --Rollo May
Great tool- expensive blades. We have a lumber yard that sells the blades individually for a reasonable price. I use the bi-metal if I even THINK a nail maybe buried. The tool can do some jobs faster and easier than any other. Good investment.
I took the plunge about 3 months ago and bought a multi-master. It is REALLY good for tight, plunge cuts such as repairing flooring. I don't need to overwork my chisel anymore! It also is a dream for making super fine cuts in pieces of moulding that need to be removed, then replaced for a project.
I haven't used all of the features yet, but I think it's worth it. You really do need to protect the blades though. They are wicked expensive and they tend to dull quickly when carving up hardwood flooring...
RR
I've always thought that if Fein was smart, they'd give the motors away. That would make more people available to buy their high priced blades, etc. It's a fantastic tool.
that's what i'm waiting on."Never pick a fight with an old man. If he can't beat you he will just kill you." Steinbeck
