Fein Multimaster: great tool!
Cooper | Posted in Tools for Home Building on April 27, 2006 11:53am
I’m sure this is old news to regulars on here, but I just got hip to the Fein Multimaster.  What a great tool!
We’re finishing a whole house remodel, and to save money on the hardwood floor refinishing, I decided to remove the stained/rotted pieces of oak hardwood myself.  Instead of having to take out the entire length of flooring, this tool enables you to cross cut with incredible precision.  After doing the floor, I used it to cut the little piece of wood that sticks out past the cabinet edge that’s usually covered by the toe kick—unbelievable control.
The kit I bought comes with a sanding kit, caulk scrapper, and grout removal blade, plus a multitude of wood/metal cutters.
Think this thing will be great for cutting out jambs for tile installations too!
So, if you’re looking for a comletely different tool to add to your remodeling tool kit, this is it.
    razzman | Apr 27, 2006 06:36pm | #1
    Dammit. There it is again.
    Sounds like that'll be the next tool for the arsenal.
    Anyone have that guys name on Ebay that sells the aftermarket blades?
    'Nemo me impune lacesset'
    1. Snort | Apr 28, 2006 12:09am | #3
      Anyone have that guys name on Ebay that sells the aftermarket blades?yup... I need a dump truck, baby, to unload my head
        razzman | Apr 28, 2006 12:45am | #4
        be yup
        'Nemo me impune lacesset'No one will provoke me with impunity
        1. Snort | Apr 28, 2006 03:06am | #7
          aye yup...what cynwood said<G> I need a dump truck, baby, to unload my head
          1. nikkiwood | Apr 28, 2006 03:12am | #9
            I have bought a fair number of blades from this ebay guy, and as far as I can tell, they are just as good as the much more expensive blades from Fein.********************************************************
            "It is what we learn after we think we know it all, that counts."
            John Wooden 1910-
    2. Cooper | Apr 28, 2006 01:27am | #5
      There are less expensive blades available on ebay?  I'd like to know that info too...
      1. cynwyd | Apr 28, 2006 02:57am | #6
        http://cgi.ebay.com/Wide-cutting-BLADE-for-Fein-Multimaster-Free-Shipping_W0QQitemZ7612270642QQcategoryZ20797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
        work very well!
    3. Shep | Apr 28, 2006 03:08am | #8
      Break out that crowbar, pry open that wallet, and buy one.
      You won't regret it.
        razzman | Apr 28, 2006 03:29am | #10
        last time I opened it a moth flew out 'cause I hadn't opened it to put anything in it either.
        be woe
        Edited 4/27/2006 8:30 pm ET by razzman
        1. Shep | Apr 28, 2006 09:41pm | #11
          ya keep buying all those closeout specials
          and you don't quite know what to do with some of it.
          Trust me, you'll use the MM.
          And you'll be kickin' yerself for not getting it sooner.
          1. cynwyd | Apr 29, 2006 12:42am | #12
            Buying a Multimaster is like when one bought an early CD player, Yes, the cost is considerable, but what you're really buying into is a system whose components add up quickly.
            I reface my H&L sanding pads by heating them, pulling off the spent material and gluing a new one on or declaring them to be PSA pads.
            I also buy 1/2 sheet loop sandpaper to cut new sanding triangles from. Easily done since I have all those patterns around.
          2. Shep | Apr 29, 2006 03:48am | #13
            I've had mine for at least 3 years now.
            Its one of the tools that would be replaced immediately if stolen.
  2. migraine | Apr 27, 2006 08:27pm | #2
    another use for the offset saw blade
    A new neighbor was complaining that most off his single hung windows don't open or barely open because the previous owner painted them closed.(can you say "flip this house").  I took the Fein tool over there and in about an hour had every window easily opening and closing.
    Now the need to be sanded and painted correctly.  Not my job...
