Fein Vac Extension hose and wand??
Ledebuhr1 | Posted in Tools for Home Building on June 25, 2009 05:03am
I am getting a Fein Turbo1 vac. I would like to get an additional section of hose that is about 6-8ft long so I can reach my entire garage, without the vac moving. I would also like to get an extension wand so I dont have to bend over.
I know Fein makes this stuff, but there prices are outragous. Is there any aftermarket companys that make a compatable hose and tube?
  1. DonNH | Jun 25, 2009 08:00pm | #1
    I bought a set of hose & attachments for my Turbo III from Amazon.  Yours probably uses the 1-1/4 standard hose, so it should be easy to find what you want - even if you just get a longer hose instead of an extension.
    Don
    hammer1 | Jun 25, 2009 08:17pm | #2
    Home Depot carries accessories for wet dry vacs. I bought a 1 1/4" Genie hose that fits my Turbo III, 10',$15. They also carry your typical plastic wands, nozzles and brushes. There must be a conspiracy regarding vac attachments, nothing seems to fit everything. You have to be creative, maybe remove the hose end, they unscrew in reverse, maybe add a couple of wraps of tape to it, maybe find other ends or adapters. The problems are encountered when connecting to a tool, too many variations.
    1. Ledebuhr1 | Jun 25, 2009 10:59pm | #3
      Thanks, that genie hose sounds like what I need. If I add a 10ft section that would make for a total of 26ft of hose, do you think that would be too long? and too much suction loss.
        hammer1 | Jun 26, 2009 04:02am | #4
        I've never used a Turbo I, Ledebuhr1. I don't know if 26' +- will have an effect. Not much stops my Turbo III except a jam in the hose, electricians boring chips are tough. It pulls just as hard full or empty. Un-jamming a long hose will present some extra work. You'll have to be careful where the hoses connect. An obstruction in the line may cause stuff to hang up.
      2. AitchKay | Jul 12, 2009 09:36pm | #6
        I have no trouble with suction loss using long hoses. My Wap is a bit more powerful than a Fein, but I don't think you'll have a problem. I often leave the vacuum in another room, with its cord plugged into a switched plug strip.AitchKay
  3. AitchKay | Jul 12, 2009 09:32pm | #5
    I use salvaged 1 1/2" pool-cleaning hose. I've got a 35-footer, but the 25-footer is the one I use most.
    The cuffs are standard, and you might be able to get an extra from a carpet cleaner. You want 2 1/2" down to 1 1/2" to fit the vac end, 1 1/2" at the wand end. They screw on to the spiral of the hose itself.
    Inexpensive metal 1 1/2" wands are hard to find, so I use old 1 1/4" household wands and heads. There's usually some monkeying around to adapt them, but often you can just jam them into the 1 1/2" cuff.
    One bonus to using the smaller wands is that it limits your clogs to the wand. I've had to stick a 20' length of pipe through my hose before, and it's annoying.
    Lengths of 1 1/2" chrome sink drain tube fit the 1 1/2" cuffs, and make good 1 1/2" to 1 1/2" splices and custom adapters.
    AitchKay
    IMERC | Jul 12, 2009 09:57pm | #7
    pool supply...
    janitor supply house...
    the supply house will have the better selection and quality...
    WOW!!! What a Ride!
  5. Scott | Jul 12, 2009 11:13pm | #8
    I've been thinking about this:
    http://www.leevalley.com/wood/page.aspx?c=1&p=47161cat=1,42401,62597,62621&ap=1
    Scott.
  6. USAnigel | Jul 13, 2009 05:04am | #9
    Look in the drywall tool section of HD and you'll fine a better hose for $15 with adaptors for almost any tool. Yellow and green box.
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
