My gate fence is falling apart. It is too far gone for repair and I’ve opted to replace it. What I need help with is this: what is the best type of joint to use on the corners of the frame? I’m planning to make the frame out of kiln-dried yellow pine 2X4s. I will be using 8′ X4″ cedar pickets. Does anyone see a problem with using yp 2X4s?
Listeners write in about ambitious projects and sinking patios before asking questions about old house specialists, attic headroom, and home shops.
I'd use cedar for the whole thing. Either pinned mortice/tennon or through mortise/tennon wedged................1/2 lap might work also if you use the proper glue and pins.
Thanks for the advice. I'm leaning toward 1/2 lap using Gorilla Glue and deck screws.
$Bill
Don't rely on that joint to keep the gate square when you hang it. In this application, the type of joint doesn't matter very much for strength in this way. You need a diagonal brace, really deep rails and stiles, or a wheel that supports the weight of the gate. You could also apply the fence boards at an angle.Tom
Pardon my ignorance. What are "rails and stiles?"$ Bill
I agree with the cedar. Most yp frames I've seen have warped in the sun. PT does weird things while drying. They'll work, but it's very much a crap-shoot over time. Looks of cedar on cedar can't be beat and it will be lighter. There's cyprus is you can find it. Think I'd stick with cedar.
__________________________________________
Calvin,
Thanks for your advice, which raises 2 questions: 1) what is PT? 2) Does cedar come in 2X4 and 2X6?
$Bill
Pressure Treated and yes, cedar does come in 2x6 and 2x4. I get some nice pcs from a fence supply co. You gotta look and pic, but their stock is, at least in this area, better priced and decent looking. Might be a place to check in your area. Here, the moisture content is a little high, but seems no problem for exterior applications. The rest of the advice you've rec. is good. Best of luck.__________________________________________
Stile... upward part...vertical piece....
Rail... cross part....horizontal piece.....
of most any construction. windows/doors/cabinet face frames/exterior trim/etc...
and usually the stiles run the full length...and the rails fit in between. Jeff * Jeff J. Buck/ Buck Construction/ Pittsburgh, PA *
2nd Generation Buck Const, 3rd generation Craftsman
Thanks Calvin!$ Bill
Thanks, Pete! That sound like a plan!
