Simpson makes them in 2 differnt lenghts , their web site might list a supplier inyour area
Mike
It’s O.k. to think out of the box, Just don’t walk off of the plank!
Edited 12/18/2002 8:06:29 AM ET by Mike S
Edited 12/18/2002 8:07:40 AM ET by Mike S
no problem, glad I could help
Mike
It's O.k. to think out of the box, Just don't walk off of the plank!
I bought 'em at HD, back by the insulation. Andy Engel, The Former Accidental Moderator
They don't work worth a lick on "I" joists. too short to reach the webs. Too much droop in the insulation if you put the wires on the ends of the joists. I used them to hold the insulation up on a ceiling to then cover with the vapor barrier, then T&G sheathing.
In your case the vapor barrier should be tword the inside of the house (Most cases). You'll need a screen or some permiable barrier if you are using I joists.
