Fiberglass Insulation in Perforated Plastic Wrapper
jimmiem | Posted in Energy, Heating & Insulation on December 5, 2013 08:09am
Do they still sell unfaced fiberglass insulation in perforated plastic?  I remember seeing something like this several years ago.  I need to add some insulation to my attic in an area where the insulation will have to be moved infrequently to access the A/C blower.  The insulation that is currently there gets ruined from all the moving around as it needs to get  pulled under the flexible A/C tubing. This insulation sits on top of the original faced insulation.  Based on the lengths I need rolls would work better than batts.
  1. DanH | Dec 05, 2013 08:49am | #1
    Yeah, they used to sell it, but I haven't seen it advertised in maybe 15 years.
    1. jimmiem | Dec 09, 2013 12:20pm | #4
      Poly-encapsulated Fiberglass Insulation
      I called Johns-Manville.  According to customer service Lowes carries it.  Not all Lowes stores may stock it but can special order it. There are also smaller lumber yards that may have it.....the one in my neck of the woods is 40 miles from my house.
    2. kxm1 | Feb 01, 2014 03:04pm | #7
      yes it is...
      ..still available.You could probably do something better for accessing the A/C equipment like building an insulation dam with rigid foam board. It would be a little work but would provide a better long term solution to your problem.
  2. calvin | Dec 05, 2013 08:00pm | #2
    Jim
    encapsulated insulation..............
    http://www.specjm.com/commercial/insulation/polyencapsulated.asp
    that was the first entry using the above search words.  Have at it.
  3. florida | Dec 06, 2013 08:37pm | #3
    Yes, and I loved it but haven't seen it in several years.
  4. albion10 | Dec 22, 2013 12:18pm | #5
    NOT FOR CEIOINGS
    iF I rember correctly this plastic wrap insulaation is not to be used in ceilings.... Rockwool insullation batts
     will stand upto moving much better ...
    1. DanH | Dec 22, 2013 02:12pm | #6
      The original Owens-Corning stuff was shown in ads being installed as "attic floor" insulation.
Fast, Accurate Wall Framing
