Fill in Basement window
BJC | Posted in Construction Techniques on June 21, 2009 06:23am
I have to fill in a small basement window so my electrician can move my circuit panel to where the window is now.
The foundation is poured concrete, and the window frame is metal. The house was built in 1974. This window is below grade with a window well.
What’s the best way to do this? My first thought was to rip out the metal frame and fill in with concrete block, but I am just worried that ripping out the metal frame might cause some bigger problems (there is about 3 inches of concrete above the window that would probably fall apart). So, my question is – keep the metal frame in or rip it out?
Thanks,
Brian
Edited 6/21/2009 11:26 am ET by BJC
  1. doodabug | Jun 21, 2009 06:28pm | #1
    I would leave it and brick in the opening.
    1. Snort | Jun 21, 2009 06:49pm | #2
      There might be a steel lintle?http://www.tvwsolar.com
      1. BJC | Jun 21, 2009 07:03pm | #3
        I think it is just the frame with no lintel. I suppose I could drill some holes into the foundation and put some rebar in through the mortar between the blocks and the foundation. I'm not sure I'd trust the mortar to bond with the metal. Or maybe I'm overthinking this... :)
        1. Snort | Jun 21, 2009 07:08pm | #4
          Yep, like Doodabug said, just leave it.http://www.tvwsolar.com
          1. silvertip | Jun 21, 2009 07:21pm | #5
            I would try and rip it out but as with most frames or the ones I have done the frame is put in place before the pour.  This would make it a *itch to get it out but not impossible.  The other thing I would be concerned with is the bond between the old and new.  If your below grade it will leak so extra attention will be needed on the exterior, I will assume you will want to remove the window well.  Post a pic would be helpful.  Also makes a difference which way your floor joists run.
          2. BJC | Jun 21, 2009 08:33pm | #8
            The joists are perpendicular to the window. Good point about the waterproofing.Here is a picture.Thanks everyone.
  2. doodabug | Jun 21, 2009 07:45pm | #6
    What is the reason the panel has to go right where the window is anyway?
    1. BJC | Jun 21, 2009 08:20pm | #7
      The old panel is right next to the boiler and that location will no longer pass code. The window was broken anyway, and I was planning to fill it in - this just brings it to the top of my list quicker.
Big Doors Have Big Challenges
Engineered materials and vacuum-press laminations prevent warping and keep a tall, flush-panel door from being excessively heavy.
