filling jersey barriers with sand
SteveInCleveland | Posted in General Discussion on October 24, 2008 05:02am
Anybody out there ever fill jersey barriers with sand?  I’m trying to think of the best method to fill them with sand efficiently.
The next project I have out in St. Louis we are going to use sand.  The thieves just puncture the water-filled ones, wait for them to drain, then proceed stealing cars.
“Preach the Gospel at all times; if necessary, use words.”  – St. Francis of Assisi
    BillHartmann | Oct 24, 2008 05:15pm | #1
    What are you calling a jersey barrier.
    What I am familiar with is a solid cast concert "inverted Tee".
    http://en.wikipedia.org/wiki/Jersey_barrier
    1. peteshlagor | Oct 24, 2008 05:25pm | #2
      I've seen those made outta plastic.  Therefore, I assume they're filled with something.
      Water sounds good for relocating frequently.
      But I don't know the size of any opening.  I further assume using very dry clean sand and a properly sized and supported funnel is gonna be his choice.
  2. DavidxDoud | Oct 24, 2008 06:03pm | #3
    they used to use buckets with a bottom valve to move/raise concrete back before pumpers - may still use them for some applications - seems like you could use them to position and dump sand into a top loading barrier -
    "there's enough for everyone"
  3. DanH | Oct 24, 2008 09:15pm | #4
    Get your concrete supplier to deliver DRY sand in a cement mixer.
    Corporation: n. An ingenious device for obtaining individual profit without individual responsibility. --Ambrose Bierce
    1. DanH | Oct 24, 2008 09:16pm | #5
      Or get the sand in one of those bags and drop it in using a fork lift.
  4. harryv | Oct 25, 2008 05:51am | #6
    How ya gonna get the sand out when you're done?
    1. DanH | Oct 25, 2008 06:23am | #7
      My standard solution: Shaped charges.
  5. super343 | Oct 25, 2008 06:39am | #8
    Hello stelen. My co bought jersey barries and I would like to fill half way with water we need to move them time to time. Now with the winter I need to put a chemeical in but must be ok to dump and not polute . I was tould the water would poss break the plastic the ice will exspand.
      BillHartmann | Oct 25, 2008 06:41am | #9
      You can use RV antifreeze..
      1. super343 | Oct 26, 2008 11:42pm | #11
        thank you
    2. DanH | Oct 25, 2008 07:11pm | #10
      Calcium chloride is probably OK with the EPA.
      1. super343 | Oct 26, 2008 11:43pm | #12
        thank you
Fast, Accurate Wall Framing
