Find an engineer
user-1115822294 | Posted in General Discussion on November 8, 2019 04:30pm
I need to hire someone to determine if a wall I want to move is load bearing. How do I find such a person?
  1. florida | Nov 10, 2019 01:39pm | #1
    Look in the phone listing under "structural engineer."
  2. DanH | Nov 10, 2019 02:28pm | #2
    If you're talking standard residential wood frame construction then any competent carpenter should be able to make the determination.
    civileng43 | Nov 11, 2019 09:01am | #3
    Unless you’ve got an extremely unique structure, I agree with DanH that the opinion of a carpenter is perfectly adequate. If you want to make your own evaluation, just go up into the attic and look which way the ceiling joists run. If they are parallel to the wall in question and there are no posts coming down from the roof, then it is extremely unlikely that the wall is loadbearing. Otherwise, you need to start looking at post and beam systems to pick up the load, but this is not the nightmare that it is sometimes made out to be. In fact, posts and beams can be used to quite an esthetic advantage.
